Newbie Solaris Question...
Christopher Plummer Christopher_Plummer at raytheon.com
Mon Sep 15 17:49:25 UTC 2003
I am using Solaris 9 if that helps any...
bash-2.05$ sparc-rtems-as -help
bash: /home/kplummer/opt/rtems/bin/sparc-rtems-as: cannot execute binary
file
I'm getting the same thing for all of the files in ~/opt/rtems/bin.
Thanks again.
Kit
Kit Plummer, Systems Engineer
Operations Research and System Performance Dept.
Raytheon Missile Systems
520-794-1552
520.794.0309 fax
christopher_plummer at raytheon.com
Joel Sherrill <joel.sherrill at OARcorp.com>
09/15/03 11:04 AM
        To:     Christopher Plummer <Christopher_Plummer at raytheon.com>
        cc:     RTEMS Users <rtems-users at rtems.com>
        Subject:        Re: Newbie Solaris Question...
Christopher Plummer wrote:
> Yep, I've set the path as such.  Not sure what I did, but I am not
getting
> this error:
> /home/kplummer/Files/SPARC_RTEMS/build/gcc/xgcc
> -B/home/kplummer/Files/SPARC_RTEMS/build/gcc/ -nostdinc
> -B/home/kplummer/Files/SPARC_RTEMS/build/sparc-rtems/newlib/ -isystem
> /home/kplummer/Files/SPARC_RTEMS/build/sparc-rtems/newlib/targ-include
> -isystem /home/kplummer/Files/SPARC_RTEMS/gcc-3.2.3/newlib/libc/include
> -B/home/kplummer/opt/rtems/sparc-rtems/bin/
> -B/home/kplummer/opt/rtems/sparc-rtems/lib/ -isystem
> /home/kplummer/opt/rtems/sparc-rtems/include -c -o crti.o -x assembler
> ../../gcc-3.2.3/gcc/config/sparc/sol2-ci.asm
> xgcc: installation problem, cannot exec
> `/home/kplummer/opt/rtems/sparc-rtems/bin/as': Exec format error
> gmake[1]: *** [crti.o] Error 1
> gmake[1]: Leaving directory `/home/kplummer/Files/SPARC_RTEMS/build/gcc'
> gmake: *** [all-gcc] Error 2
> gmake: Leaving directory `/home/kplummer/Files/SPARC_RTEMS/build'
> The 'as' that it is trying to use is the one from the
> sparc-rtems-binutils-2.13.2.1-2.t fi.
If you invoke "sparc-rtems-as --version", what happens?
--joel
> Kit
> 520-794-1552
> 520.794.0309 fax
> gregory.menke at gsfc.nasa.gov
> 09/15/03 10:16 AM
>         To:     "Christopher Plummer" <Christopher_Plummer at raytheon.com>
>         Subject:        Newbie Solaris Question...
> Christopher Plummer writes:
>  > Hey guys,
>  > I am trying to get the RTEMS setup going on a Solaris box.  I want to
> get
>  > the UNIX/emulator kernel running locally to do some preliminary
> testing,
>  > but am having trouble getting GCC to compile.  Here's what I've done
to
>  > this point - I'm hoping someone can give the steps to get this thing
>  > going...
>  > Downloaded the sparc-rtems files for binutils, gcc, and c++ and
> unpacked
>  > them.  I've exported the PATH to include the new opt/rtems directory.
>  > Next, I created a build directory, cded into into and ran the
configure
>  > command for GCC - which goes good.  When I run gmake it errs during
>  > compile with:
>  > -isystem
assembler
>  > .../../gcc-3.2.3/gcc/config/sparc/sol2-ci.asm
>  > xgcc: installation problem, cannot exec `as': No such file or
directory
>  > Any ideas?  Steps?
> Is the ~/opt/rtems/bin directory in your path?
> Gregm
