Newbie Solaris Question...
Christopher Plummer Christopher_Plummer at raytheon.com
Mon Sep 15 18:30:36 UTC 2003
I guess I am gonna try and compile the binutils from scratch...Ihaven't
tried that yet.  I did try to compile the newlib stuff from scratch once
without luck.   Thanks...maybe I'll just have to go back to Sol9.
Kit
Kit Plummer, Systems Engineer
Operations Research and System Performance Dept.
Raytheon Missile Systems
520-794-1552
520.794.0309 fax
christopher_plummer at raytheon.com
Joel Sherrill <joel.sherrill at OARcorp.com>
09/15/03 12:23 PM
        To:     gregory.menke at gsfc.nasa.gov
        cc:     Christopher Plummer <Christopher_Plummer at raytheon.com>,
RTEMS Users <rtems-users at rtems.com>
        Subject:        Re: Newbie Solaris Question...
gregory.menke at gsfc.nasa.gov wrote:
> Did you compile binutils, or install from an rpm.  If rpm, perhaps its
> bad?
The Solaris binaries are cross-compiled from Linux -> Solaris 8.
It is certainly possible they do no thave some magic bit set
but this procedure has worked in the past.  I have heard of no
other problems with the Solaris binaries.
<grin> Of course, that could mean that there are no Solaris users.
--joel
> Gregm
> Christopher Plummer writes:
>  > I am using Solaris 9 if that helps any...
>  > bash-2.05$ sparc-rtems-as -help
>  > bash: /home/kplummer/opt/rtems/bin/sparc-rtems-as: cannot execute
binary
>  > file
>  > I'm getting the same thing for all of the files in ~/opt/rtems/bin.
>  > Thanks again.
>  > Kit
>  > 520-794-1552
>  > 520.794.0309 fax
>  > 09/15/03 11:04 AM
>  >         To:     Christopher Plummer
>  >         cc:     RTEMS Users <rtems-users at rtems.com>
>  > Christopher Plummer wrote:
>  > > Yep, I've set the path as such.  Not sure what I did, but I am not
>  > getting
>  > > this error:
>  > > /home/kplummer/Files/SPARC_RTEMS/build/gcc/xgcc
>  > > -B/home/kplummer/Files/SPARC_RTEMS/build/gcc/ -nostdinc
>  > > -B/home/kplummer/Files/SPARC_RTEMS/build/sparc-rtems/newlib/
-isystem
/home/kplummer/Files/SPARC_RTEMS/build/sparc-rtems/newlib/targ-include
>  > > -isystem
/home/kplummer/Files/SPARC_RTEMS/gcc-3.2.3/newlib/libc/include
>  > > -B/home/kplummer/opt/rtems/sparc-rtems/bin/
>  > > -B/home/kplummer/opt/rtems/sparc-rtems/lib/ -isystem
>  > > /home/kplummer/opt/rtems/sparc-rtems/include -c -o crti.o -x
assembler
>  > > ../../gcc-3.2.3/gcc/config/sparc/sol2-ci.asm
>  > > xgcc: installation problem, cannot exec
>  > > `/home/kplummer/opt/rtems/sparc-rtems/bin/as': Exec format error
>  > > gmake[1]: *** [crti.o] Error 1
>  > > gmake[1]: Leaving directory
`/home/kplummer/Files/SPARC_RTEMS/build/gcc'
>  > > gmake: *** [all-gcc] Error 2
>  > > gmake: Leaving directory `/home/kplummer/Files/SPARC_RTEMS/build'
>  > > The 'as' that it is trying to use is the one from the
>  > > sparc-rtems-binutils-2.13.2.1-2.t fi.
>  > If you invoke "sparc-rtems-as --version", what happens?
>  > --joel
>  > > Kit
>  > > 520-794-1552
>  > > 520.794.0309 fax
>  > > 09/15/03 10:16 AM
>  > >         To:     "Christopher Plummer"
>  > >         Subject:        Newbie Solaris Question...
>  > >  > Hey guys,
>  > >  > I am trying to get the RTEMS setup going on a Solaris box.  I
want to
>  > > get
>  > >  > the UNIX/emulator kernel running locally to do some preliminary
>  > > testing,
>  > >  > but am having trouble getting GCC to compile.  Here's what I've
done
>  > to
>  > >  > this point - I'm hoping someone can give the steps to get this
thing
>  > >  > going...
>  > >  > Downloaded the sparc-rtems files for binutils, gcc, and c++ and
>  > > unpacked
>  > >  > them.  I've exported the PATH to include the new opt/rtems
directory.
>  > >  > Next, I created a build directory, cded into into and ran the
>  > configure
>  > >  > command for GCC - which goes good.  When I run gmake it errs
during
>  > >  > compile with:
-isystem
>  > >  > -isystem
>  > assembler
>  > >  > .../../gcc-3.2.3/gcc/config/sparc/sol2-ci.asm
>  > >  > xgcc: installation problem, cannot exec `as': No such file or
>  > directory
>  > >  > Any ideas?  Steps?
>  > > Is the ~/opt/rtems/bin directory in your path?
>  > > Gregm
>  > Joel Sherrill, Ph.D.             Director of Research & Development
>  > joel at OARcorp.com                 On-Line Applications Research
>  > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>  > Support Available                (256) 722-9985
