RTEMS for MIPS
Ren, Han Tao (Hans) renht at lucent.com
Tue Sep 16 06:39:03 UTC 2003
Ralf
I'm a little confused.  Should I add "-rtems" option  when build
mips-rtems-gcc?  Could you give more details?
When I built mips-rtems-gcc.  I just run
../gcc-3.2.2/configure --target=mips-rtems \
--with-gnu-as --with-gnu-ld --with-newlib --verbose \
--enable-threads --prefix=/opt/rtems
make all
make info
make install
And I got the mips-rtems-gcc mips-rtems-gcc, but it failed on compiling the
sample code of  RTEMS.
Thanks
Hans
-----Original Message-----
From: Ralf Corsepius [mailto:corsepiu at faw.uni-ulm.de]
Sent: Tuesday, September 16, 2003 2:25 PM
To: Ren, Han Tao (Hans)
Cc: RTEMS mailing list
Subject: RE: RTEMS for MIPS
On Tue, 2003-09-16 at 07:51, Ren, Han Tao (Hans) wrote:
> What is "qrtems"?
-qrtems is a gcc option implemented into a BSP's bsp_specs and gcc's
global specs-file, used as a short-cut to pick up rtems-specific
settings in calls to gcc.
Ralf
> Hans
> ->Seems as if the -qrtems somehow gets lost. I don't know if you made a
> ->typo somewhere, or if something is broken elsewhere.
> Ralf
