How many bytes?
Tue Sep 16 10:59:53 UTC 2003
shannon wrote:
>There are four 32-bit members in structure Heap_Block, but the size of Heap_Block is 8. Why? Does the 8 mean 8*8-bit or 8*16-bit or 8*32-bit.
There are two 32-bit values required to managed a block in the heap when
it is
free or in use. It takes 2 more to manage it when it is free. So you end up
with a minimum heap block size of 8 bytes out of 16 bytes used.
>        shannon
>        zhou_xingjian at 163.com
>          2003-09-16
