longcall probelm (RE: was MVME2304 Exception 3 )
Feng, Shuchen
feng at bnl.gov
Wed Sep 17 17:46:19 UTC 2003
Hi all,
I could not use the -mlongcall flag to compile my application.
I do not know if I need to rebuild my toolchains with a specific option
or the rs6000.c file needs to be patched. I am heading both directions
with no conclusion. Hopefully, someone can shed some light for
me.
I believe the -mlongcall flag will solve the error message I ran to
with the MVME2304-0141 board. Probably Till does not need to rebuild the
GeSys binary. Without rebuilding the vxWorks image, we used the -mlongcall
option for the EPICS base and application on the same board and it works.
The error I got while loading the object code is :
"Relocation of type 'R_PPC_REL24' failed: The relocation was performed,
but there was an overflow (check compiler flags!)"
On August 18, Paul Jines wrote :
> We are trying to run RTEMS on a MVME2304-0143 and are experiencing
Exception 3 errors.
> The exception 3's occur most of the time, but maybe 10% of the time do NOT
occur and run the
> GeSys application. It has never succeeded in running the epics
applications.
Te MVME2304-0141 board is the same as Paul's MVME2304-0143 with 128 MB.
Based on my experience with the MVME2306 board, the exception 3 could be
caused by
the improper setup of the hardware or VME crate as well.
Regards,
kate
