Always return?
Thu Sep 18 11:10:13 UTC 2003
Ian Caddy wrote:
>Hi,
>In this function size is an unsigned32 so effectively the comparison is
>to compare whether size is getting close to the limit of an unsigned32.
>The negative number is converted to an unsigned32 which causes it to be
>a very large positive number for the comparison.
Correct. And it might also make sense to further limit the size of the
maximum request. Anything greater than sizeof RAM minus the code space
is always unsatisfiable.
--joel
>Hope this helps,
>Ian Caddy
>shannon wrote:
>>  if ( size >= (-1 - HEAP_BLOCK_USED_OVERHEAD) )
>>      return( NULL );
>>This is a sentence in heapallocate.c. I think size is more than 0, and (-1-HEAP_BLOCK_USED_OVERHEAD) equals -9. Then the routine will be returned. Is what I think right? However, should the routine exit here?
>>             shannon
>>          2003-09-18
