Line Discipline or Termios lacks ?
Cedric Aubert cedric_aubert at yahoo.fr
Thu Sep 18 15:06:04 UTC 2003
--- Thomas Doerfler <Thomas.Doerfler at imd-systems.de>
wrote:
> Hello Cedric,
> rtems termios has a feature to control the hardware
> handshake
> lines (or, actually, only the RTS line) to signal to
> the
> oposite side, that the receive buffer is almost
> full, or that
> there is more space available. This features is
> available in
> some console drivers, it depends on the
> implementation of the
> "stopRemoteTx" and "startRemoteTx" hooks.
> If the hardware driver in use supports these calls
> and the
> device has the CRTSCTS flag set, then termios will
> control the
> hardware handshake output line RTS for you.
Yes, I see this features ! It's ok transfert RTS/CTS
control. But I need to manualy control RTS/CTS or DSR
or DTR or CD on some device, I don't found this
feature
on termios.
> This has nothing to do with "line discipline". The
> "line
> discipline" feature allows redirecting the character
> stream to
> certain additional, external functions, that can do
> wierd
> things like decoding the incoming character stream
> as PPP
> packets and so on.
> If the functionality in termios for hardware
> handshake line
> control is not sufficent for you, you might add
> "private"
> functions to the "ioctl" function of your device
> driver, which
> might in turn do whatever you want with the hardware
> handshake
> lines of your devices.
Ok, I want to do this !! :-) But I don't found how
termios_ioctl will call my private driver ioctl
function.
Termios_icotl have a switch(command) :
case KnwonCommand1 :
case KnwonCommand2 :
case KnwonCommand3 :
default : Call line discipline ioctl function
So How can I do, that's what I don't understand and
found a solution to do this and use termios ?
> wkr,
> 	Thomas.
AUBERT Cedric
SDEL Controle Commande
rue Nungesser & Coli
44860 St Aignan de Grand Lieu
E-mail : cedric_aubert at yahoo.fr
Http : http://www.controle-commande.sdel.fr/
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
