Line Discipline or Termios lacks ?
Thu Sep 18 15:50:16 UTC 2003
Thomas Doerfler wrote:
> Hi,
>>Ok, I want to do this !! :-) But I don't found how
>>termios_ioctl will call my private driver ioctl
>>function.
>>Termios_icotl have a switch(command) :
>>case KnwonCommand1 :
>>case KnwonCommand2 :
>>case KnwonCommand3 :
>>default : Call line discipline ioctl function
> Well, I would not change the termios code, but intercept the
> ioctl call in your private driver.
Nice suggestion.  Would you mind making it a subsection of
the BSP and Device Driver chapter on serial devices?
Also I have searched a bit and not managaed to find a standard
way of doing this function.  If there is a way on *BSD or Linux
to do this, it would be nice to use those names for the IOCTLS
and possibly add them to the standard list.
> Whenever an application performs an ioctl call for a specific
> device, then the RTEMS io system calls the "ioctl" function in
> the device driver (e.g. "console_ioctl"). A "nomal" driver
> supporting "termios" will only hand through that call to
> termios_ioctl, in that case the drivers "ioctl" function looks
> like:
>  * Handle ioctl request.
> rtems_device_driver console_control(
>   rtems_device_major_number major,
>   rtems_device_minor_number minor,
>   void                    * arg
>   return rtems_termios_ioctl (arg);
> In your case, you should intercept your own ioctl code in this
> function, so you would change it to:
>   void                    * arg
>   rtems_status_code rc;
>   rtems_libio_ioctl_args_t *args = arg;
>   switch(args->command) {
>     case_MY_IOCTL_CODE_TO_ENABLE_RTS:
>       rc = console_enable_rts(arg);
>       break;
>     case_MY_IOCTL_CODE_TO_DISABLE_RTS:
>       rc = console_disable_rts(arg);
>       break;
>     default:
>       rc = rtems_termios_ioctl (arg);
>       break;
>   return rc;
> Does this help a bit?
> wkr,
> 	Thomas.
>>So How can I do, that's what I don't understand and
>>found a solution to do this and use termios ?
>>>wkr,
>>>	Thomas.
>>AUBERT Cedric
>>SDEL Controle Commande
>>rue Nungesser & Coli
>>44860 St Aignan de Grand Lieu
>>E-mail : cedric_aubert at yahoo.fr
>>Http : http://www.controle-commande.sdel.fr/
>>__________________________________
>>Do you Yahoo!?
>>Yahoo! SiteBuilder - Free, easy-to-use web site design software
>>http://sitebuilder.yahoo.com
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-
> systems.de/pgp_keys.htm
