CPU usage statistics
Thu Sep 25 21:54:49 UTC 2003
Charles Steaderman wrote:
> I would like to gather some CPU usage statistics on my system. I found
> a function named CPU_usage_Dump() which seems to be close to what I
> need. After looking though the code, it is not clear how "system" or
> "interrupt" time is measured. Does RTEMS have a way to segment system
> time usage from normal task usage or does interrupt processing time
> count against the task that is interrupted?
The latter --   interrupt processing time is included in the interrupted
task.  To do otherwise, the
RTEMS interrupt dispatcher would have to do some timer management.
> - Charlie
