Eclipse IDE for RTEMS?
Thomas Rauscher trauscher at loytec.com
Fri Sep 26 15:55:38 UTC 2003
On Tue, 16 Sep 2003, Rosimildo da Silva wrote:
> Thomas Rauscher wrote:
> >On Mon, 15 Sep 2003, Michael Kelly wrote:
> >>Hi all,
> >>The Eclipse IDE is getting a lot of press and looks pretty nice.
> >>There were several articles in todays EE Times about it. I was
> >>wondering if anyone has set Eclipse up to build and debug RTEMS.
> >>Michael
> >We are quite happy with Eclipse.
> >You can use Eclipse with minor modifications for cross-development.
> >The CDT (C/C++ Development Tools) project provides anything needed to edit
> >C/C++ files, build projects and start an external debugger (using the gdb
> >machine interface).
> >You need to provide:
> >- A Makefile for your project (should be there anyway)
> >- A gdb-script invoked when a debugging session starts.
> >Best regards,
> >Thomas
> >Dipl.-Ing. Thomas Rauscher                 Tel.:   ++43 1 402 08 05 15
> >                                           Fax:    ++43 1 402 08 05 99
> >LOYTEC electronics GmbH                    E-mail: trauscher at loytec.com
> >Stolzenthalergasse 24/3, A-1080 Wien       Web:    http://www.loytec.com
> A little "HOW-TO" document this, could be very helpful, since Eclipse is
> a nice IDE, as long as you have a very fast PC. But, if you are using
> GCC, you probably have it.
> Rosimildo.
Please try the following (applies to Eclipse 2.1.1).
1) IMPORTANT: Cross-Debug Workaround for the GDB/MI interface. (Found
   in the Eclipse news groups.)
   In file plugins/org.eclipse.cdt.debug.mi.core_1.0.0/plugin.xml
   change the lines
     cpu="native"
     into
     cpu="native,mycpu1,mycpu2"
   where mycpu1, mycpu2, ... are the cpu names used by GDB, e.g.
   "arm,i386,..."
2) Write a debugger script .gdbinit that contacts your target and
   loads the symbol table or a program. It should do something like
     target <connect options>
     load <my program name>
     <whatever else is needed to get the board running>
   Of course this script is highly target and application dependent.
   I let my application Makefile generate it automatically.
   Then start your debugger
     mytarget-gdb -x .mygdbinit
   and test that you can debug your target this way.
3) Configure an Eclipse Debugging session
   Create a new Debugging Session and name it.
   Change the following tabs:
   Main Tab
	Select your project
	Select an application (does not matter because the application
	  is selected by the .gdbinit script, but Eclipse requires to
	  set it)
   Debugger
	Select GDB Debugger or GDB Cygwin Debugger
	GDB Debugger: Set path to mytarget-gdb
	GDB Command File: Path to .mygdbinit
   Click Apply
4) Start the session
   Power on the target.
   Click "Debug" or select your Configuration from the Bug Icon.
   Eclipse now should start the selected gdb with the selected debugger
   script. The target should break in main() and you should be able to
   debug now.
Let me know, if this works for you.
Best regards,
Thomas Rauscher
