Address error
Leon Pollak leonp at plris.com
Wed Sep 3 09:02:49 UTC 2003
Thomas,
	You are great!!!!!!
	I don't know how to thank you - I brake my head already for the second day,
but do not see this simple difference in declarations!
	1001 of thanks to you!!!
On Wednesday 03 September 2003 11:35, Thomas Doerfler wrote:
> Hello Loen,
> maybe the answer is in the definition of your _output_char
> function.
> AFAIK "BSP_output_char" should be a pointer to a output
> function, like:
> BSP_output_char_function_type      BSP_output_char;
> Initially it should point to a dummy function that performs
> nothing. When your serial I/O is up and running, you can move
> the pointer to the corresponding function.
> void my_output_char_fnc(char c)
> 	/* output my character */
> void console_init( blablabla)
>    /* init my output device */
>    BSP_output_char = my_output_char_fnc;
> I guess you have named your output function as
> "BSP_output_char", but printk assumes this "label" is a
> pointer to the function, not the fucntion code itself.
> Does this fit your problem?
> wkr,
> 	Thomas.
> > Hello,
> > 	I see that my first mail was formulated unclear.
> > 	Here is the next attempt :-))
> > 	I have RH9 running the last tools and snapshot, my own BSP derived form
> > mbx860 via bdm.
> > 	The printk function tries to call my BSP_output_char via vprintk. The
> > map shows that BSP_output_char resides at 0x34330.
> > 	Below is the assembler of the call:
> >     0x17a14 <vprintk+1056>:	lis	r11,3	                    R11=0x30000
> >     0x17a18 <vprintk+1060>:	lwz	r9,8(r31)
> >     0x17a1c <vprintk+1064>:	lbz	r0,0(r9)
> >     0x17a20 <vprintk+1068>:	clrlwi	r0,r0,24
> >     0x17a24 <vprintk+1072>:	lwz	r11,17200(r11)       R11=0x9421ffe0 ?????
> >     0x17a28 <vprintk+1076>:	mtctr	r11
> >     0x17a2c <vprintk+1080>:	mr	r3,r0
> >     0x17a30 <vprintk+1084>:	bctrl
> > 	The address which is put into CTRL register is 0x9421ffe0. It is the
> > content of 0x34330 (assembler commands of BSP_output_char ).
> > 	The question is why the code tries to call THIS function indirectly,
> > while the calling address is direct?
> > Any help will be VERY highly appreciated...
> > leonp at plris dot com
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-
> systems.de/pgp_keys.htm
Dr.Leon M.Pollak
Director
PLR Information Systems Ltd.
