sparc-rtems-size
Fabio Degiovanni - Eicas
degiovanni at eicas.it
Mon Sep 8 13:13:52 UTC 2003
I have two another questions, probably trivial questions but I am new at
this things:
-why is the dimension of the executable code far bigger then the text
dimension given by sparc-rtems-size? It's also bigger then the code+data
dimension given by sparc-rtems-size. What's the meaning of the
executable dimension?
-why are the sectons .text .data and .bss evaluated using
sparc-rtems-size on the object far smaller then the .text .data and .bss
evaluated using sparc-rtems-size on the executable? I think this is due
to the linking of my object with the rtems libraries to produce the
executable. What are the rtems libraries that are linked with my code?
Thank you very much
Fabio Degiovanni
Joel Sherrill wrote:
> Fabio Degiovanni - Eicas wrote:
>> What are the exact meaning of the field "text" "data" and "bss" given
>> by the sparc-rtems-size utility?
> I was surprised that this wasn't in the binutils size man page. :(
> .text is where the executable code goes. Sometimes it may also
> hold read only data. .text should be able to be placed in ROM
> or Flash.
> .data is initialized global/static variables.
> .bss is uninitialized global/static variables.
> On top of that, you have dynamic heap and RTEMS work space usage
> which cannot be determined by size.
>> Thank you very much
>> Fabio Degiovanni
Dott. Ing. Degiovanni Fabio
Eicas Automazione
Via Vincenzo Vela, 27 10128 Torino (ITALIA)
Telefoni +39-11-562.37.98/562.3088 Fax +39-11-436.06.79
