mips: genmongoosev/start/start.S
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Wed Sep 10 02:46:33 UTC 2003
On Tue, 2003-09-09 at 17:26, gregory.menke at gsfc.nasa.gov wrote:
> Ralf Corsepius writes:
> > > > Hi,
> > > > May-be there's a mips-expert on this list, who can help:
> > > > Compiling genmongoosev/start/start.S with gcc-3.3.2pre and binutils-2.14
> > > > fails with this error:
> > > > # mips-rtems4.7-gcc --pipe -B../../../../../../../lib/
> > > > -B../../../../../../../genmongoosev/lib/ -specs bsp_specs -qrtems -mips1
> > > > -G0 -isystem ../../../../../../../genmongoosev/lib/include -DASM -o
> > > > o-optimize/start.o -c
> > > > .../../../../../../../../../../rtems.master/c/src/lib/libbsp/mips/genmongoosev/start/start.S
> > > > .../../../../../../../../../../rtems.master/c/src/lib/libbsp/mips/genmongoosev/start/start.S: Assembler messages:
> > > > .../../../../../../../../../../rtems.master/c/src/lib/libbsp/mips/genmongoosev/start/start.S:585: Error: load/store address overflow (max 32 bits)
> > > > .../../../../../../../../../../rtems.master/c/src/lib/libbsp/mips/genmongoosev/start/start.S:620: Error: load/store address overflow (max 32 bits)
> > > > .../../../../../../../../../../rtems.master/c/src/lib/libbsp/mips/genmongoosev/start/start.S:628: Error: load/store address overflow (max 32 bits)
> > > > AFAIS, all lines gas is complaining about are of this type:
> > > > sw t0,M_BIU
> > > > gcc-3.2.x/binutils-2.13.x compiled this file without any complaint.
> > > > So, what is it that cause gcc-3.3.x/binutils-2.14 to fail?
> > > > Invalid ASM, previous versions of the toolchain has let pass through? A
> > > > bug in gcc-3.3.x, binutils-2.14? Invalid compiler options not matching
> > > > the expectations of this *.S-file?
> > > I haven't upgraded to gcc 3.3 yet, so I can't test directly.
> > Don't! It seems to be horribly broken. At least I just have encountered
> > a breath-taking bug in gcc-3.3.2pre, which I verified to break at least
> > mips-rtems and i386-rtems, and suspect to probably break all rtems-gccs,
> > if not many more targets.
> > These "M_BIU" type of arguments are defines, aren't they?
> > If so, the bug I just tripped over, could be an explanation.
My assumption was wrong. Meanwhile I can demonstrate that this issue is
not related to gcc-3.3, but to binutils-2.14:
When compiling start.S into a start.s (gcc --save-temps), either with
gcc-3.2.3 or gcc-3.3.2, both start.s files basically are identical, but
binutils-2.14 is not able to compile it.
Proof:
Compiling start.S with gcc-3.2.3:
# mips-rtems4.6-gcc --pipe -B../../../../../../../lib/ -B../../../../../../../genmongoosev/lib/ -specs bsp_specs -qrtems -mips1 -G0 -isystem ../../../../../../../genmongoosev/lib/include -DASM -o o-optimize/start.o -c ../../../../../../../../../../rtems-4-6-branch/c/src/lib/libbsp/mips/genmongoosev/start/start.S -v --save-temps
/opt/rtems-4.6/lib/gcc-lib/mips-rtems4.6/3.2.3/../../../../mips-rtems4.6/bin/as -G0 -mips1 -v -o o-optimize/start.o start.s
GNU assembler version 2.13.2.1 (mips-rtems4.6) using BFD version 2.13.2.1
=> binutils-2.13.2.1 assembled start.s without complaint.
Now, assembling the start.s which has been produced during the gcc-3.2.3
call, using binutils-2.14:
# /opt/rtems-4.7/lib/gcc-lib/mips-rtems4.7/3.3.2/../../../../mips-rtems4.7/bin/as -G0 -mips1 -v -o o-optimize/start.o start.s
GNU assembler version 2.14 (mips-rtems4.7) using BFD version 2.14 20030612
../../../../../../../../../../rtems-4-6-branch/c/src/lib/libbsp/mips/genmongoosev/start/start.S: Assembler messages:
../../../../../../../../../../rtems-4-6-branch/c/src/lib/libbsp/mips/genmongoosev/start/start.S:585: Error: load/store address overflow (max 32
bits)
../../../../../../../../../../rtems-4-6-branch/c/src/lib/libbsp/mips/genmongoosev/start/start.S:620: Error: load/store address overflow (max 32
bits)
../../../../../../../../../../rtems-4-6-branch/c/src/lib/libbsp/mips/genmongoosev/start/start.S:628: Error: load/store address overflow (max 32
bits)
Note: start.s is the same file, start.s has been generated by gcc-3.2.3,
the call to as uses identical arguments.
=> It's not directly gcc-3.3's fault.
This indicates, that one or more points from this list below might
apply:
* Assembling start.s trips bugs in binutils-2.14.
* binutils-2.14 catches bugs in start.S which binutils-2.13.2.1 had let
slip through.
* binutils-2.14 might require further/different options/arguments to
assemble start.S
Ralf
