RTEMS for MIPS
Ren, Han Tao (Hans)
renht at lucent.com
Tue Sep 16 07:35:32 UTC 2003
Thomas
Thank you for your message.
Yes, I've installed the BSP to opt/rtems/mips-rtems/.
Let me give more details on what I did.
Actually, I got different toolchains, one is "sparc-rtems", one is
"mips-rtems".
I download the binaries of "sparc-rtems" on http://www.gaisler.com, but I
had
to build toolchains for mips-rtems myself, so I download binutils and gcc
source
code, as well as the patch files for RTEMS. Then I followed the
instructions in
the document "Getting Started with RTEMS for C/C++ Users(4.6.0pre4)" to do
the building, it passed finally and I got the binaries, but it seemed
mips-rtems-gcc
refused to work. However, the sparc-rtems toolchains are working fine.
The following
are some log messages.
[root at localhost samples]# mips-rtems-gcc -g -O2 hello.c -o hello
/opt/rtems/lib/gcc-lib/mips-rtems/3.2.2/../../../../mips-rtems/bin/ld:
warning: cannot find entry symbol _start; defaulting to 0000000000400020
/tmp/cccZsyHs.o: In function `main':
/opt/rtems/src/examples/samples/hello.c(.text+0x10): undefined reference to
`puts'
collect2: ld returned 1 exit status
[root at localhost samples]# sparc-rtems-gcc -g -O2 hello.c -o hello
[root at localhost samples]# mips-rtems-gcc -g -O2 -rtems rtems-hello.c -o
rtems-hello
mips-rtems-gcc: unrecognized option `-rtems'
rtems-hello.c:7:17: bsp.h: No such file or directory
rtems-hello.c:11: parse error before "Init"
rtems-hello.c:12: parse error before "ignored"
rtems-hello.c:31:22: confdefs.h: No such file or directory
[root at localhost samples]# sparc-rtems-gcc -g -O2 -rtems rtems-hello.c -o
rtems-hello
I've tried on both Redhat and Solaris platform, the results are same.
Thanks
Hans
Hans
-----Original Message-----
From: Thomas Doerfler [mailto:Thomas.Doerfler at imd-systems.de]
Sent: Tuesday, September 16, 2003 3:00 PM
To: Ren, Han Tao (Hans)
Subject: Re: RTEMS for MIPS
Hello,
this is just a guess: Maybe you forgot to "install" the BSP
you have built. Normally, after configuring and building the
BSP, it sould be installed with
make install
this will copy the relevant files to a path like
/opt/rtems/mips-rtems/<bsp>/*
Whenever you try to build an application, the compiler
normally tries to find the include files and libraries in that
path...
And, naturally, Ralf is right, the command line switch "-
qrtems" should be visible on the compiler command line. So
maybe you simply misstyped your command line and the switch "-
rtems" should in fact be "-qrtems"?
wkr,
Thomas.
> Hello
> I just follow the instructions in the document "Getting Started with RTEMS
> for C/C++ Users(4.6.0pre4)" to build the toolchains and RTEMS for MIPs.
> I've successfully built all the toolchains. But when I specified the bsp
as
> "p4600", It failed when building RTEMS. Then I configured the bsp as
> "jmr3904" and it passed. However, when I built the sample code, it report
> the following error messages.
> $ mips-rtems-gcc -g -O2 -rtems rtems-hello.c -o rtems-hello
> Does anybody know where the problem is?
> Thanks
> Hans
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_keys.htm
