Rough evaluation of execution time
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Tue Sep 16 09:20:07 UTC 2003
Hello Fabio,
I am not a ERC32 specialist, but I had a short look at the
simulator. I found out two thing:
If I simply enter
$ sparc-rtems-sis --help
I get the following output:
zerberus:/home/thomas # /opt/rtems/bin/sparc-rtems-sis --help
SIS - SPARC intruction simulator 2.7.5, copyright Jiri Gaisler 1995
Bug-reports to jgais at wd.estec.esa.nl
unknown option --help
usage: sis [-uart1 uart_device1] [-uart2 uart_device2]
[-nfp] [-freq frequency] [-c batch_file] [files]
[-sparclite] [-dumbio]
I would assume that you can specify the system frequency that
you want to simulate with option "-freq"
If I start the simulator, and enter the "perf" command, I get
the following line in output:
ERC32 performance (14.0 MHz): nan MOPS ( nan MIPS, nan
MFLOPS)
so I would assume, that the ERC32 is simulated by default with
a 14 MHz clock. Does this make sense?
I general, good simulators will simulate the behaviour of the
chip on a system clock per clock basis. So the events ocurring
in the simulated chip really do not depend on the speed of the
host computer, that simulates the chip. Assuming a 14MHz
clock, the RTEMS time-of-day should be incremented by one
second, when 14 million clock cycles have been simulated. I
treally doesn't matter in this situation, whether your host
computer has taken 100 Milliseconds or 10 Minutes to simulate
these 14 Million clock events.
Does this help you a bit?
wkr,
Thomas.
> Dear Sirs,
> In the last days I sent some questions about a rough evaluation of
> execution time using gdb/sis simulator of ERC32. Some of my questions
> didn't find an answer. I kindly ask anyone of you that could help me to
> reply this message when you find time.
> Could anyone told me where I can find what erc32 is simulated by sis/gdb
> (a 10, 14, or 15 Mhz or what)?
> Joel Sherrill told me that the simulator's notion of
> time is independent of the host computer's
> speed. What about the time resolution? I presume that this is host
> computer dipendent. In which way? When I use the
> CONFIGURE_MICROSECONDS_PER_TICK for configuring time resolution in RTEMS
> do I affect the time resolution of the simulator or is it host computer
> dependent?
> Thank you very much for help
> Fabio Degiovanni
> Dott. Ing. Degiovanni Fabio
> Eicas Automazione
> Via Vincenzo Vela, 27 10128 Torino (ITALIA)
> Telefoni +39-11-562.37.98/562.3088 Fax +39-11-436.06.79
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_keys.htm
