execution stops at rtems_rate_monotonic_create() ?
kmedri kmedri kmedri at hotmail.com
Mon Apr 5 17:25:10 UTC 2004
>There is an error message in kph_task which says you couldn't create the
>period and then the test exits.  I suppose that the console IO is not
>being flushed completely.
I have added fflush() to tasks.c prior to the suspect exit statement in the
following place:
//this is not reached
puts( "kph_task has stopped executing\n" );
fflush(NULL);
No improvement. I was also wondering - the other tasks do not even
successfully
indicate that they are called. I tried exit(1); prior to the
rtems_rate_monotonic_create() - it allows a clean reboot while with my
current
problem the system just hangs.
I appreciate help in getting my tasks to run, thanks
_________________________________________________________________
Free yourself from those irritating pop-up ads with MSn Premium. Get 2months
FREE*
http://join.msn.com/?pgmarket=en-ca&page=byoa/prem&xAPID=1994&DI=1034&SU=http://hotmail.com/enca&HL=Market_MSNIS_Taglines
