execution stops at rtems_rate_monotonic_create() ?
kmedri kmedri
kmedri at hotmail.com
Tue Apr 6 17:51:27 UTC 2004
>Is it possible that you are using an application Makefile based
>upon hello world? If so, then it is linking in stubs for
>optional managers. IThe rate monotonic manager is definitely
>optional so every call would return not configured. It is
>also quick possible that the clock manager is stubbed as well.
>Look at the Makefile and the gcc command that is printed to
>link the applciation.
Thanks for the help. Here is the Makefile (I think initially based on the
test_tasks example) that I am using along with a more appropriate manager
statement for my program:
# Makefile
# RTEMS_MAKEFILE_PATH is set in an environment variable
EXEC=bike.exe
PGM=${ARCH}/$(EXEC)
# optional managers required
#MANAGERS=io
#http://www.rtems.com/ml/rtems-users/2003/may/msg00025.html
#however http://www.rtems.com/ml/rtems-users/2000/july/msg00095.html
MANAGERS=all
# C source names
CSRCS = bike.c tasks.c port_sim.c
COBJS_ = $(CSRCS:.c=.o)
COBJS = $(COBJS_:%=${ARCH}/%)
# C++ source names
CXXSRCS =
CXXOBJS_ = $(CXXSRCS:.cc=.o)
CXXOBJS = $(CXXOBJS_:%=${ARCH}/%)
# AS source names
ASSRCS =
ASOBJS_ = $(ASSRCS:.s=.o)
ASOBJS = $(ASOBJS_:%=${ARCH}/%)
# Libraries
LIBS = -lrtemsall -lc
include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
include $(RTEMS_CUSTOM)
include $(PROJECT_ROOT)/make/leaf.cfg
OBJS= $(COBJS) $(CXXOBJS) $(ASOBJS)
all: ${ARCH} $(PGM)
$(PGM): $(OBJS)
$(make-exe)
j:
@echo $(CFLAGS_DEBUG_V)
@echo $(RTEMS_USE_GCC272)
_________________________________________________________________
Add photos to your messages with MSN Premium. Get 2 months FREE*
http://join.msn.com/?pgmarket=en-ca&page=byoa/prem&xAPID=1994&DI=1034&SU=http://hotmail.com/enca&HL=Market_MSNIS_Taglines
