how to use rtems_task_variable_add ?
Alan Cudmore Alan.P.Cudmore at nasa.gov
Wed Apr 7 20:48:55 UTC 2004
I want to add a variable to my task context using
rtems_task_variable_add.
The variable is a global unsigned integer:
uint32 os_task_key;
I want to set this to a unique value in each task and have the OS save
and restore it for me.
How do I pass this in to the void **ptr type in the call?
calling it like this:
    rtems_status =  rtems_task_variable_add ( rtems_task_id,
&os_task_key, NULL );
gives me a warning. Do I need to do something like the following?
void *task_var_ptr;
task_var_ptr = (void *)&os_task_key;
rtems_status = rtems_task_variable_add(rtems_task_id, &task_var_ptr,
NULL );
Thanks,
alan
