bug in gcc-3.2.3/gcc/gthr_rtems.h
Till Straumann strauman at slac.stanford.edu
Wed Apr 21 05:55:21 UTC 2004
Joel Sherrill wrote:
> Till Straumann wrote:
>> I think Yacine is right. Looking at gcc-3.2.2 is affected, too.
>> Joel apparently added a macro definition on 2003-05-21 (gcc PR 9296)
>> - however, the reasons for this change are not apparent.
>> Joel, can you remember why you thought you had to define
>> __GTHREAD_MUTEX_INIT ?
> I will double check myhself tomorrow but this does NOT
> appear to fix the problem for me.  Maybe it is a build/install/test
> confusion so I will double check.  Has one of you successfuly
> made this work with that mod?
Well - it seemed to me that Yacine did. I didn't do a runtime check but
my good friend 'nm' tells me:
without mod:
[tillpc]> nm -Au libstdc++.a | grep rtems_gxx_mutex_init
libstdc++.a:eh_alloc.o:rtems_gxx_mutex_init
with mod (i.e., __GTHREAD_MUTEX_INIT *not* defined):
libstdc++.a:globals.o:rtems_gxx_mutex_init
-- Till
>> Thanks
>> -- Till
>> The Changelog
>> EL KOLLI Yacine wrote:
>>> Hello,
>>> I think there is a bug in gthr_rtems.h in the gcc-3.2.3 source tree
>>> under gcc-3.2.3/gcc/gthr_rtems.h.
>>> In this file   __GTHREAD_MUTEX_INIT is define to 0 and
>>> __GTHREAD_MUTEX_INIT_FUNCTION   is defined to rtems_gxx_mutex_init.
>>> But a comment in gthr.h states:
>>>          to initialize __gthread_mutex_t to get a fast
>>>     non-recursive mutex.
>>>          some systems can't initialize a mutex without a
>>>     function call.  On such systems, define this to a
>>>     function which looks like this:
>>>     void __GTHREAD_MUTEX_INIT_FUNCTION (__gthread_mutex_t *)
>>>     Don't define __GTHREAD_MUTEX_INIT in this case
>>> The result of having defined __GTHREAD_MUTEX_INIT is that the STL
>>> global constructor does not call rtems_gxx_mutex_init to init its
>>> mutex, but rather use the statically defined value 0.
>>> All locking performed by the STL lib on this mutex fail with return
>>> value OBJECT_ERROR, which seems not be tested.
>>> I've recompiled gcc with __THREAD_MUTEX_INIT left undefined. Now STL
>>> constructor is calling rtems_gxx_mutex_init , and nothing seems broken.
>>> Any comments ?
>>> Y El Kolli.
