bug in gcc-3.2.3/gcc/gthr_rtems.h
Wed Apr 21 16:04:32 UTC 2004
EL KOLLI Yacine wrote:
>>> Comment interleaved, hope it helps..
>> I think we are getting there.  We might be fixing two things. :(
> well that can be a good news ;o)
>>>> I rebuilt completely a toolset and RTEMS for psim so that
>>>> shouldn't be a problem.
>>>> I am still not getting a break at rtems_gxx_mutex_init
>>>> and the test is obviously failing.
>>> Are you sure that your c++ test is using STL ?
>> Hmmm.. that may be a hint.  I added your list
>> code before the cout.  Now rtems_gxx_mutex_init
>> is being called but the test fails on the cout.
>> Can you run the cdtest when
>> RTEMS_TEST_IO_STREAM is defined in main.cc?
> yes and It works.
> I've modified the _Thread_Handler function to make it calling _eabi()
> instead of _init(). I've done this a while a go, when I was trying to
> get the IO streams working. But I'don't remember if that solves my
> problem, nor why I have not submitted the modification :o(.
> When you run cdtest global constructors should print a message on sreen
> before the main message. Do you have the print out from the global
> constructors ?
*** CONSTRUCTOR/DESTRUCTOR TEST ***
LOCAL: Hey I'm in base class constructor number 1 for 0x7e94b8.
LOCAL: Hey I'm in base class constructor number 2 for 0x7e94c8.
LOCAL: Hey I'm in base class constructor number 3 for 0x7e94d8.
LOCAL: Hey I'm in base class constructor number 4 for 0x7e94e8.
LOCAL: Hey I'm in derived class constructor number 5 for 0x7e94e8.
core_find_mapping() - access to unmaped address, attach a default map to
handle this - addr=0xfffffff4 nr_bytes=0x4 processor=0x407c9008 cia=0x492d4
I forced a call to __eabi() which ended up calling _init, doing
a few instructions and returning.  _init() is called from
_Thread_Handler so that seems OK.  The _init body is only this:
0x55a10 <_init>:        stwu    r1,-16(r1)
0x55a14 <_init+4>:      mflr    r0
0x55a18 <_init+8>:      stw     r0,20(r1)
0x55a1c <_init+12>:     lwz     r0,20(r1)
0x55a20 <_init+16>:     mtlr    r0
0x55a24 <_init+20>:     addi    r1,r1,16
0x55a28 <_init+24>:     blr
Does this more or less match yours?
The linker script has to be just right to make the constructors
happen.  I copied the ctor/dtor pattern from the gen405 but without
luck.  Could you see what might be broken in the psim linkcmds?
--joel
