AT91RM9200 and RTEMS
Ole Hansen Ole at danelec.dk
Wed Apr 28 11:48:23 UTC 2004
Hello rtems-users
We are going to use RTEMS and Atmel AT91RM9200 and wondered:
The ARM920T - core used in AT91RM9200 seems to have 2 instruction-sets.
1. ARM High-performance 32-bit Instruction set
2. Thumb High Code Density 16-bit Instruction Set
Which one is used to build RTEMS/compile application for RTEMS ?????
Anybody know the performance difference running from 32-bit SDRAM or 16-bit SRAM ???
 best regards
 ole at danelec.dk
* Software Manager
 * danelec electronics a/s
 * Blokken 44
 * DK-3460 Birkeroed
 * DENMARK
  * Phone: +45 45821879
   * Fax:  +45 45821979
    * Email: ole at danelec.dk
     * http://www.danelec.dk
      * ftp://ftp.danelec.dk
       * Radio call sign: oz1jru
        *    If you seek luck, luck will strike you ..... 8o)         *
