RTEMS on ARM
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Apr 5 20:20:02 UTC 2004
Jay Monkman wrote:
> On Mon, Apr 05, 2004 at 08:48:56AM -0300, Jairo Cavanus wrote:
>>uC?s configuration:
>> AT91FR4042: ARM 7 82Mhz, 512 KB Flash + 256 KB SRAM
>>(http://www.atmel.com/dyn/products/product_card.asp?part_id=1983);
>> AT91FR40162: ARM 7 82Mhz, 2 MB Flash + 256 KB SRAM
>>(http://www.atmel.com/dyn/products/product_card.asp?part_id=1985);
>>The one that I need besides the kernel is the basic TCP/IP + PPP...
>>Will I need external Flash or SRAM?
> That depends on your application, but for an Atmel AT91RM9200 (ARM9),
> here's the sizes of the sample programs:
> text data bss dec hex filename
> 113663 3020 47104 163787 27fcb arm-rtems/csb337/samples/base_sp.exe
> 88807 2968 39168 130943 1ff7f arm-rtems/csb337/samples/hello.exe
> 268135 8328 51200 327663 4ffef arm-rtems/csb337/samples/loopback.exe
> 88923 2968 39168 131059 1fff3 arm-rtems/csb337/samples/minimum.exe
> 177555 3428 48384 229367 37ff7 arm-rtems/csb337/samples/paranoia.exe
> 442929 16096 81408 540433 83f11 arm-rtems/csb337/samples/pppd.exe
> 115551 3020 45056 163627 27f2b arm-rtems/csb337/samples/ticker.exe
> 116943 2968 43776 163687 27f67 arm-rtems/csb337/samples/unlimited.exe
> That indicates it would fit in your part, (maybe not the 512K one) but
> executing out of flash, which is somewhat slower than sram.
First... I didn't connect the csb337 as being an ARM9 and anyone who
asks me about specific ARM part numbers like that long Atmel is
usually going to get a long blank stare. :)
Jay have you ever looked at the symbol table for those executables or
the output of -Map with the linker?
Since minimum and hello are essentially the same size, that indicates
that at least printf() is being forced in by the BSP or some ARM
support code. It is also possible that the BSP has some unnecessary
references to subsystems that are not used in minimal configurations.
--joel
