execution stops at rtems_rate_monotonic_create() ?
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Apr 6 13:26:34 UTC 2004
kmedri kmedri wrote:
>> Did you put in the CONFIGURE_MAXIMUM_PERIODS so this error wouldn't
>> even have happened?
> Yes, here's a breakdown of my posts on this topic so far:
I think I answered privately but want this in the email logs.
Is it possible that you are using an application Makefile based
upon hello world? If so, then it is linking in stubs for
optional managers. IThe rate monotonic manager is definitely
optional so every call would return not configured. It is
also quick possible that the clock manager is stubbed as well.
Look at the Makefile and the gcc command that is printed to
link the applciation.
> http://www.rtems.com/ml/rtems-users/2004/april/msg00000.html
> Initial post with code
> http://www.rtems.com/ml/rtems-users/2004/april/msg00001.html
> Addition of #include <rtems/rtems/ratemon.h>
> http://www.rtems.com/ml/rtems-users/2004/april/msg00004.html
> Addition of #define CONFIGURE_MAXIMUM_PERIODS 10
> http://www.rtems.com/ml/rtems-users/2004/april/msg00008.html
> Addition of fflush(NULL);
> Thanks again
> _________________________________________________________________
> MSN Premium: Up to 11 personalized e-mail addresses and 2 months FREE*
> http://join.msn.com/?pgmarket=en-ca&page=byoa/prem&xAPID=1994&DI=1034&SU=http://hotmail.com/enca&HL=Market_MSNIS_Taglines
