pc386 PCI question
gregory.menke at gsfc.nasa.gov
Tue Apr 6 14:27:17 UTC 2004
Joel Sherrill writes:
> This was sent directly to me and the return address
> appeared to be hidden. First, I don't know what network
> device driver is being used. Second, this is an
> apparent inconsistency in the i386/shared code. The
> file pci/pcibios.c is referencing those symbols
> (BusCountPCI and BSP_pciFindDevice) and I do not know
> where (or if) they are supposed to be. I would appreciate
> some insite from someone out there so this can really be
> resolved.
> --joel
This is the case where the x86 and ppc PCI support not being
integrated is causing trouble. These functions were originally
implemented in libbsp/powerpc/shared/pci, but lacking a unified PCI
api, some time ago I ported them to i386/shared/pcibios.c to provide
functionality in support of the elnk and dec21140 drivers.
i386/shared/pci/pcibios.c implements BSP_pciFindDevice, but that
function requires BusCountPCI. However I don't see where BusCountPCI
got off to- it should be imiplemented in pcibios.c. I think it got
removed somehow since I did build-test the drivers for i386. Until
someone who knows how to make the pcibios calls in i386 go shows up to
obtain a real bus count, a temporary workaround could be to add the
following to pcibios.c;
unsigned char BusCountPCI()
return 1;
this will support pci busses with no bridges to secondary busses,
which should handle pc kinds of systems. A proper solution is to use
the pcibios calls to probe the PCI bus at boot time to find its
extent.
Gregm
