How many Timers Can I Create???
Tue Apr 13 14:34:55 UTC 2004
Alex wrote:
> It is more clear now for me...
> So, the my problem is due configuration of rtems itself, right?
> I have to find out how to change rtems configuration to be possible to create hundreds of timers...
First you need to modify cpukit/sapi/include/confdefs.h per the
email I posted yesterday so it accounts for timer resources
properly.  Here is the URL to that message
http://www.rtems.com/ml/rtems-users/2004/april/msg00050.html
Then you simply need to define the CONFIGURE_XXX constant
appropriately.
Finally let us all know.
--joel
> Thanks to all
> Alex
> ----- Mensagem Original -----
> De: Joel Sherrill <joel.sherrill at OARcorp.com>
> Data: Segunda-Feira, 12 de Abril de 2004, 17:43
> Assunto: Re: How many Timers Can I Create???
>>Alex wrote:
>>>Ok, but I am still looking to this behaiviour as strange,
>>because the pc I am using has 256 MB of ram and if the rtems see
>>memory as a flat fashion, It looks like that rtems is waisting
>>memory in timers... Sorry about my statement ... I am beginner in
>>rtems, but now I am interesting in find out the reason... I think
>>we all!
>>>So if with 256 mb rtems only allows to create 10 timers, well If
>>we need 20 timers We have to put ~512 Mb on the PC. It looks very
>>strange...
>>It doesn't matter how much physical RAM is in your target hardware.
>>What matters is how much you told RTEMS it had available to use.
>>In the deeply embedded world, one wants tight control over
>>memory layout and usage.  The amount you want RTEMS to use
>>is calculated by confdefs.h and it doesn't get a byte more.
>>Your C program heap may be huge on that PC but RTEMS is
>>likely being told to use just a handful of kilobytes.
>>--joel
>>>Alex
>>>Data: Segunda-Feira, 12 de Abril de 2004, 17:18
>>>>Kamen Penev wrote:
>>>>>Joel Sherrill wrote:
>>>>>>Alex wrote:
>>>>>>>Hi,
>>>>>>>Does RTEMS has a confifured maximum number o timers it
>>>>supports, or
>>>>>>>it naturally crashs when too much timers are created?
>>>>>>>In an test I am doing I have the following:
>>>>>>>#define CONFIGURE_MAXIMUM_POSIX_TIMERS 150
>>>>>>>#define CONFIGURE_MAXIMUM_ 150
>>>>>>>Then I have source code to create 100 timers, but when the
>>>>program
>>>>>>>starts it hangs, even before starting sreating the first
>>>>timer. The
>>>>>>>timers are created with the timer_create POSIX function.
>>>>>>Sounds like the BSP was unable to assign the memory for that much
>>>>>>workspace.
>>>>>I see this in confdefs.h (ss-20030417):
>>>>>#define CONFIGURE_MEMORY_FOR_POSIX_TIMERS(_timers) \
>>>>>((_timers) * \
>>>>> ( 0 ) )
>>>>>Maybe this is why?
>>>>That would explain it also. :)
>>>>I would guess that the proper definitions in
>>>>cpukit/sapi/include/confdefs.h should be:
>>>> ((_timers) * sizeof(POSIX_Timer_Control))
>>>>And since POSIX timers implicitly use a Classic API timer:
>>>>#define CONFIGURE_MEMORY_FOR_TIMERS(_timers) \
>>>> ((_timers + CONFIGURE_MAXIMUM_POSIX_TIMERS) * \
>>>>    ( sizeof(Timer_Control) + CONFIGURE_OBJECT_TABLE_STUFF ) )
>>>>My earlier statement about the bspstart.c failing still
>>>>apply.  But this time you probably got slightly further
>>>>in initialization before things failed.  RTEMS initialization
>>>>probably ran out of workspace duging the preallocation of
>>>>object control blocks.
>>>>If this works, let us know so a PR can be filed.
>>>>>Kamen
>>___________________________________________________________________________________________> IOL Flash. A net normal em versao acelerada.
>>>Promocao: Ligue-se a Internet pelo IOL Flash e ganhe um Vale de
>>€10 da Galp!
>>>Saiba como:
>>http://www.iol.pt/central_utilizador/iol_flash/promocao.php>
> Promocao: Ligue-se a Internet pelo IOL Flash e ganhe um Vale de €10 da Galp!
> Saiba como: http://www.iol.pt/central_utilizador/iol_flash/promocao.php
