bug in gcc-3.2.3/gcc/gthr_rtems.h
EL KOLLI Yacine
yacine.elkolli at crf.canon.fr
Wed Apr 21 14:57:53 UTC 2004
Joel Sherrill wrote:
> EL KOLLI Yacine wrote:
>> Comment interleaved, hope it helps..
> I think we are getting there. We might be fixing two things. :(
well that can be a good news ;o)
>>> I rebuilt completely a toolset and RTEMS for psim so that
>>> shouldn't be a problem.
>>> I am still not getting a break at rtems_gxx_mutex_init
>>> and the test is obviously failing.
>> Are you sure that your c++ test is using STL ?
> Hmmm.. that may be a hint. I added your list
> code before the cout. Now rtems_gxx_mutex_init
> is being called but the test fails on the cout.
> Can you run the cdtest when
> RTEMS_TEST_IO_STREAM is defined in main.cc?
yes and It works.
I've modified the _Thread_Handler function to make it calling _eabi()
instead of _init(). I've done this a while a go, when I was trying to
get the IO streams working. But I'don't remember if that solves my
problem, nor why I have not submitted the modification :o(.
When you run cdtest global constructors should print a message on sreen
before the main message. Do you have the print out from the global
constructors ?
>> If no STL constructor is called then gxx_muext_init will not.
>> With my test software I was getting gxx_mutex_init called once without
>> the patch, and called 3 times with the patch.
>> try adding the following lines to the cdtest sample:
>> #include <list>
>> cdtest(void){
>> std::list<int> int_list;
>> for (int i=0;i<10;i++) int_list.push_front(i);
>>> My patch to gthr-rtems is:
>>> diff -uNr /usr1/rtems/work-tools/original/gcc-3.2.3/gcc/gthr-rtems.h
>>> --- /usr1/rtems/work-tools/original/gcc-3.2.3/gcc/gthr-rtems.h Wed
>>> Jan 29 09:57:53 2003
>>> +++ gcc-3.2.3/gcc/gthr-rtems.h Tue Apr 20 14:17:52 2004
>>> @@ -37,7 +37,6 @@
>>> #define __GTHREADS 1
>>> #define __GTHREAD_ONCE_INIT 0
>>> -#define __GTHREAD_MUTEX_INIT 0
>>> #define __GTHREAD_MUTEX_INIT_FUNCTION rtems_gxx_mutex_init
>> I have the same patch
>>> Yacine, what BSP are you using? Could you confirm things
>>> with psim?
>> I'am using gen405 bsp.
>> I've never played with psim, I'll give it a try, but this may take
>> some time
>>>>> -- Till
>>>>>>> Thanks
>>>>>>> -- Till
>>>>>>> The Changelog
>>>>>>>> Hello,
>>>>>>>> I think there is a bug in gthr_rtems.h in the gcc-3.2.3 source
>>>>>>>> tree under gcc-3.2.3/gcc/gthr_rtems.h.
>>>>>>>> In this file __GTHREAD_MUTEX_INIT is define to 0 and
>>>>>>>> __GTHREAD_MUTEX_INIT_FUNCTION is defined to rtems_gxx_mutex_init.
>>>>>>>> But a comment in gthr.h states:
>>>>>>>> to initialize __gthread_mutex_t to get a fast
>>>>>>>> non-recursive mutex.
>>>>>>>> some systems can't initialize a mutex without a
>>>>>>>> function call. On such systems, define this to a
>>>>>>>> function which looks like this:
>>>>>>>> void __GTHREAD_MUTEX_INIT_FUNCTION (__gthread_mutex_t *)
>>>>>>>> Don't define __GTHREAD_MUTEX_INIT in this case
>>>>>>>> The result of having defined __GTHREAD_MUTEX_INIT is that the
>>>>>>>> STL global constructor does not call rtems_gxx_mutex_init to
>>>>>>>> init its mutex, but rather use the statically defined value 0.
>>>>>>>> All locking performed by the STL lib on this mutex fail with
>>>>>>>> return value OBJECT_ERROR, which seems not be tested.
>>>>>>>> I've recompiled gcc with __THREAD_MUTEX_INIT left undefined. Now
>>>>>>>> STL constructor is calling rtems_gxx_mutex_init , and nothing
>>>>>>>> seems broken.
>>>>>>>> Any comments ?
>>>>>>>> Y El Kolli.
EL KOLLI Yacine | yacine.elkolli at crf.canon.fr
Canon C.R.F. | Phone: +33.(0)2.99.87.68.79
http://www.crf.canon.fr | FAX: +33.(0)2.99.84.11.30
