Sysctl problems
Chris Johns
chrisj at rtems.org
Fri Apr 23 01:49:44 UTC 2004
James Yates wrote:
> I am in the process of bringing up a network app with my BSP. During a
> call to rtems_bsdnet_initialize, a call is made to
> sysctl_register_all. This in turn registers a oid to the head of the
> list. Sysctl_register_all then calls sysctl_register_oid for
> the next in the list. On entry this assigns a pointer to the parent
> which is 0xffffffff. This then immediately bombs. Has anyone
> come across this problem before. I am sure that there is some
> configuration problem with what I have done but I am really
> stuck as to how to fix this.
> Any help would be gratefully received.
Check your linker command file is handling the sysctl sections correctly.
