gdb build instructions for 4.6.1 wrong
Peter Dufault dufault at hda.com
Sun Aug 15 16:09:09 UTC 2004
The gdb instructions in the 4.6.1 "Getting started with RTEMS" document
are wrong
(http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.1/share/rtems/
html/started/started00043.html).
It says to get the patch file:
gdb-5.2-rtems-20030211.diff
but the patch files for 5.2 for that date are:
gdb-5.2-rtems-base-20030211.diff
gdb-5.2-rtems-rdbg-20030211.diff
gdb-5.2-rtems-cg-20030211.diff
I'm assuming I should apply the "base" patches, the "rdbg" patches if
I'm using "rdbg", but I'm not sure what the "cg" patches are.
Peter
Peter Dufault
HD Associates, Inc.
