Develop RTEMS under Debian
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Aug 20 17:59:24 UTC 2004
Pablo Casado wrote:
> you used alien incorrectly, alien is a perl script to convert a redhat
> rpm package into a debian deb package so the correct way to install the
> toolset would be
> alien --to-deb  -i autoconf-rtems-2.57-1.noarch.rpm
> to convert it into a deb package and then to install this package
> dpkg  -i autoconf-rtems-2.57-1.noarch.deb
Pablo could you write a patch to the Getting Started manual
(file doc/started/binaries.t) which adds a section on Debian
format packages and Alien.
Thanks.
--joel
> Pablo
> Sergey Ablalimov wrote:
>> I don't remember. Now I use Red Hat 8 and can't reproduce errors.
>> Friday, August 20, 2004, 4:38:46 PM, you wrote:
>>> On Fri, 2004-08-20 at 12:12, Sergey Ablalimov wrote:
>>>> Hello Yanjun. About 1 year ago I use Debian. When I do
>>>>      alien -i autoconf-rtems-2.57-1.noarch.rpm
>>>>      alien -i automake-rtems-1.7.2-1.noarch.rpm
>>>> I get error,
>>> Which errors do you get?
>>>> Hope this help.
>>> Not really, if you Debian users don't tell us which errors you see,
>>> nobody will be able to fix them.
>>> Ralf
