"build_alias" again in cygwin
Steve Holle sholle at link-comm.com
Wed Aug 25 14:17:00 UTC 2004
I'm the co-worker Steve Strobel referred to.  I can't say for sure but the
one thing I did that Steve hasn't was to go through and upgrade everything
that showed needing upgrade in my cygwin tree.  I have to suspect this is a
cygwin problem but am not sure why mine builds.  If there is some info from
my system someone thinks would be helpful, let me know and I'll post it.
I am still not able, however, to do an incremental build so each build
takes 30 minutes.  I would not recommend cygwin for anyone starting a new
RTEMS project.  The time wasted is huge.
At 10:57 AM 8/24/2004, Steve Strobel wrote:
>No resolution was posted because no resolution was found :(  When I tried
>to build RTEMS last week, I couldn't seem to get past the "build alias"
>problem even following the same process that has worked most of the time
>in the past.  But one of my co-workers (with an identical computer except
>for some software installations) can get it to build most of the time.  I
>just use the libraries he builds, and so am getting by for now.
>Steve
>At 02:49 PM 8/17/2004 -0400, you wrote:
> >I seem to be having basically the same problem that Steve Strobel had
> back in Jan 2002 with thread called ""build alias" trouble under cygwin".
> >It seems to be a random thing. He removed his virus checker and got it
> maybe working better. (Mine is locked in with a p/w which I don't have.)
> Also, changing the ./configure script parameters around sometimes made it
> better. In the end, no resolution was posted.
> >My /usr/bin/sh is definitely bash:
> >$ sh --version
> >GNU bash, version 2.05b.0(1)-release (i686-pc-cygwin)
> >Copyright (C) 2002 Free Software Foundation, Inc.
> >Sometimes ./configure will finish, sometimes not. Also, when it does,
> "make all" will fail with complaint about build_alias too.
> >I do see some "no" results on the ./configure before the build_alias
> failure (see below). The one that looks odd is "check if cross
> compiling... no."
> >$ ../rtems-4.6.1/configure --target=powerpc-rtems --disable-posix
> --disable-networking --disable-cxx --en able-rtemsbsp=gen405
> --prefix=/opt/rtems-4.6 | grep no$
> >checking for gmake... no
> >checking whether to enable maintainer-specific portions of Makefiles... no
> >checking if the test suites are enabled? ... no
> >checking whether we are cross compiling... no
> >configure: error: invalid variable name: build_alias
> >configure: error: /bin/sh
> '../../../../rtems-4.6.1/tools/cpu/generic/configure' failed for generic
> >configure: error: /bin/sh '../../../rtems-4.6.1/tools/cpu/configure'
> failed for tools/cpu
> >-gene
>Steve Strobel
>Link Communications, Inc.
>1035 Cerise Rd
>Billings, MT 59101-7378
>(406) 245-5002 ext 102
>(406) 245-4889 (fax)
>WWW: http://www.link-comm.com
>MailTo:steve at link-comm.com
Steve Holle
1035 Cerise Rd.
Billings, MT  59101
