Download helper? [was: build_alias]
Scott Newell
newell at cei.net
Wed Aug 25 19:31:12 UTC 2004
I was going to grab the latest Cygwin tools (m68k target) to check on the
build_alias problem (I saw it on a machine *not* running a virus scanner),
but the download helper isn't. I selected RTEMS 4.6.1, target m68k, Cygwin
host, tool source and C++ binaries. No binaries available for Cygwin? OK,
I can build from source...but the links are apparently borked:
ftp://ftp.rtems.com/pub/rtems/cygwin/rtems-4.6/rtems-4.6-binutils-2.13.2.1-
2/SOURCES/binutils-2.13.2.1.tar.bz2
ftp://ftp.rtems.com/pub/rtems/cygwin/rtems-4.6/rtems-4.6-gcc3.2.3newlib1.11
.0-3/SOURCES/gcc-3.2.3.tar.bz2
.0-3/SOURCES/gcc-3.2.3-rtems-20040108.diff
.0-3/SOURCES/newlib-1.11.0-rtems-20030605.diff
ftp://ftp.rtems.com/pub/rtems/cygwin/rtems-4.6/rtems-4.6-gdb-5.2-1/SOURCES/
gdb-5.2.tar.gz
gdb-5.2-rtems-base-20030211.diff
gdb-5.2-rtems-cg-20030211.diff
gdb-5.2-rtems-rdbg-20030211.diff
What did I do wrong?
newell
