Download helper? [was: build_alias]
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Wed Aug 25 20:22:57 UTC 2004
Scott Newell wrote:
> I was going to grab the latest Cygwin tools (m68k target) to check on the
> build_alias problem (I saw it on a machine *not* running a virus scanner),
> but the download helper isn't.  I selected RTEMS 4.6.1, target m68k, Cygwin
> host, tool source and C++ binaries.  No binaries available for Cygwin?  OK,
> I can build from source...but the links are apparently borked:
The helper is putting an extra cygwin in the path. :(  I don't see it at
first glance in the script.  The real path is:
ftp://ftp.rtems.com/pub/rtems/cygwin/rtems-4.6/
> ftp://ftp.rtems.com/pub/rtems/cygwin/rtems-4.6/rtems-4.6-binutils-2.13.2.1-
> 2/SOURCES/binutils-2.13.2.1.tar.bz2
> ftp://ftp.rtems.com/pub/rtems/cygwin/rtems-4.6/rtems-4.6-gcc3.2.3newlib1.11
> .0-3/SOURCES/gcc-3.2.3.tar.bz2
> .0-3/SOURCES/gcc-3.2.3-rtems-20040108.diff
> .0-3/SOURCES/newlib-1.11.0-rtems-20030605.diff
> ftp://ftp.rtems.com/pub/rtems/cygwin/rtems-4.6/rtems-4.6-gdb-5.2-1/SOURCES/
> gdb-5.2.tar.gz
> gdb-5.2-rtems-base-20030211.diff
> gdb-5.2-rtems-cg-20030211.diff
> gdb-5.2-rtems-rdbg-20030211.diff
> What did I do wrong?
> newell
