"build_alias" again in cygwin
Scott Newell newell at cei.net
Fri Aug 27 13:00:02 UTC 2004
At 11:16 PM 8/26/2004 , Ralf Corsepius wrote:
>> configure: error: invalid variable name: build_alias
>... I see symptoms of one of my favorite suspects ... ;)
>Can you please send me the <srcdir>/cpukit/libmisc/configure script of
>the source tree that you had used when building?
Absolutely.  It's ~148k, so I'll attach it to a private email rather that
clutter the list.
PATH=/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/cygdrive/g/WIN2K/system32:
/cygdrive/g/WIN2K:/cygdrive/g/WIN2K/System32/Wbem:/cygdrive/d/apps/cvs:/usr/
bin:/cygdrive/d/apps/diab/4.3g/win32/bin:/cygdrive/d/apps/tex/miktex/bin:/cy
gdrive/c/util:/cygdrive/d/apps/bc5/BIN:/cygdrive/c/DOS:/cygdrive/c/DOS:/opt/
>> rtems-4.6/bin
>Same comment as to Steve H.: This should be
>PATH=/opt/rtems-4.6/bin:[...]
Sorry, I missed that.  Will modify and try again.  BTW, the docs at:
http://www.rtems.org/onlinedocs/releases/rtemsdocs-4.6.1/share/rtems/html/s
tarted/started00055.html
are wrong...
>> cygwin                  1.5.5-1            OK
>AFAIK, this version is known to be problematic, but, as mentioned
>before, I am not using Cygwin, so I don't know for sure.
I'll keep that in mind if the path reorder doesn't fix it.
>> What else can I do to narrow down the cause?
>I'd be highly interested in seeing your
><sourcedir>/cpukit/libmisc/configure, after the breakdown has occurred.
Coming up...
newell
