"build_alias" again in cygwin
Scott Newell newell at cei.net
Fri Aug 27 13:40:53 UTC 2004
At 11:16 PM 8/26/2004 , Ralf Corsepius wrote:
>Same comment as to Steve H.: This should be
>PATH=/opt/rtems-4.6/bin:[...]
Reordering the path didn't help:
configure: running /bin/bash
'../../../../../../../../rtems-4.6.1/c/src/lib/libb
sp/m68k/gen68340/configure' --prefix=/opt/rtems-4.6
'--prefix=/opt/rtems-4.6' '
--host=m68k-rtems' '--build=i686-pc-cygwin' '--target=m68k-rtems'
'--disable-pos
ix' '--disable-networking' '--disable-cxx'
'--with-target-subdir=m68k-rtems' '--
exec-prefix=/opt/rtems-4.6/m68k-rtems' 'build_alias=i686-pc-cygwin'
'host_alias=
m68k-rtems' 'target_alias=m68k-rtems' 'RTEMS_BSP=gen68340'
'RTEMS_CPU_MODEL=m683
40' 'RTEMS_BSP_FAMILY=gen68340' 'CPU_CFLAGS=-mcpu32' 'CFLAGS_OPTIMIZE_V=-O4
-fom
it-frame-pointer' '--srcdir=../../../../../../rtems-4.6.1/c/src/lib/libbsp'
'--c
ache-file=/dev/null'
'--srcdir=../../../../../../../rtems-4.6.1/c/src/lib/libbsp
/m68k' --cache-file=/dev/null
--srcdir=../../../../../../../../rtems-4.6.1/c/src
/lib/libbsp/m68k/gen68340
configure: error: invalid variable name: build_alias
configure: error: /bin/bash
'../../../../../../../../rtems-4.6.1/c/src/lib/libbs
p/m68k/gen68340/configure' failed for gen68340
'../../../../../../../rtems-4.6.1/c/src/lib/libbsp/m
68k/configure' failed for m68k
'../../../../../../rtems-4.6.1/c/src/lib/libbsp/conf
igure' failed for lib/libbsp
gmake[2]: *** [mvme147] Error 1
gmake[2]: Leaving directory `/build-rtems/m68k-rtems/c'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/build-rtems/m68k-rtems/c'
gmake: *** [all-recursive] Error 1
$ echo $PATH
/opt/rtems-4.6/bin/:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin
newell
