"build_alias" again in cygwin
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Aug 27 14:36:27 UTC 2004
Scott Newell wrote:
> At 11:16 PM 8/26/2004 , Ralf Corsepius wrote:
>>>configure: error: invalid variable name: build_alias
>>... I see symptoms of one of my favorite suspects ... ;)
>>Can you please send me the <srcdir>/cpukit/libmisc/configure script of
>>the source tree that you had used when building?
> Absolutely.  It's ~148k, so I'll attach it to a private email rather that
> clutter the list.
> PATH=/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/cygdrive/g/WIN2K/system32:
> /cygdrive/g/WIN2K:/cygdrive/g/WIN2K/System32/Wbem:/cygdrive/d/apps/cvs:/usr/
> bin:/cygdrive/d/apps/diab/4.3g/win32/bin:/cygdrive/d/apps/tex/miktex/bin:/cy
> gdrive/c/util:/cygdrive/d/apps/bc5/BIN:/cygdrive/c/DOS:/cygdrive/c/DOS:/opt/
>>>rtems-4.6/bin
>>Same comment as to Steve H.: This should be
>>PATH=/opt/rtems-4.6/bin:[...]
> Sorry, I missed that.  Will modify and try again.  BTW, the docs at:
> http://www.rtems.org/onlinedocs/releases/rtemsdocs-4.6.1/share/rtems/html/s
> tarted/started00055.html
> are wrong...
Those correspond to somewhere in docs/started.  Could you please provide
a patch which fixes the problem?
