make problem with cygwin
Scott Newell newell at cei.net
Fri Aug 27 17:25:15 UTC 2004
At 11:31 AM 8/27/2004 , Ralf Corsepius wrote:
>All I can tell is:
>* Steve H. reports not to have problems.
>AFAICT, his machine seems to be up to date or at least very close to
>current Cygwin.
>* Scott report to have problems. His installation is somewhat outdated.
And Scott is still having problems:
configure: creating ./config.status
configure: configuring in ../../cpukit
configure: running /bin/bash
'../../../../../rtems-4.6.1/c/src/../../cpukit/configure'
'--prefix=/opt/rtems-4.6' '--host=m68k-rtems' '--build=i686-pc-cygwin'
'--target=m68k-rtems' '--disable-posix' '--disable-networking'
'--disable-cxx' '--with-target-subdir=m68k-rtems'
'--exec-prefix=/opt/rtems-4.6/m68k-rtems' 'build_alias=i686-pc-cygwin'
'host_alias=m68k-rtems' 'target_alias=m68k-rtems' 'RTEMS_BSP=dmv152'
'RTEMS_CPU_MODEL=m68020' 'RTEMS_BSP_FAMILY=dmv152' 'CFLAGS_OPTIMIZE_V=-O4
-fomit-frame-pointer' '--with-project-root=../../' '--enable-rtemsbsp=dmv152'
   --cache-file=/dev/null
--srcdir=../../../../../rtems-4.6.1/c/src/../../cpukit
configure: error: invalid variable name: build_alias
configure: error: /bin/bash
'../../../../../rtems-4.6.1/c/src/../../cpukit/configure' failed for
../../cpukit
gmake[2]: *** [mvme147] Error 1
gmake[2]: Leaving directory `/build-rtems/m68k-rtems/c'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/build-rtems/m68k-rtems/c'
gmake: *** [all-recursive] Error 1
This error occured after I updated cygwin.
Cygwin Package Information
Package                 Version            Status
_update-info-dir        00227-1            OK
ash                     20040127-1         OK
autoconf                2.59-1             OK
autoconf-devel          2.59-1             OK
autoconf-stable         2.13-5             OK
automake                1.7.9-1            OK
automake-devel          1.8.5-1            OK
automake-stable         1.4p6-2            OK
base-files              3.0-3              OK
base-passwd             1.1-1              OK
bash                    2.05b-16           OK
bc                      1.06-1             OK
binutils                20040725-2         OK
bison                   20030307-1         OK
byacc                   1.9-1              OK
bzip2                   1.0.2-5            OK
check                   0.8.4-1            OK
clear                   1.0-1              OK
clisp                   2.33.1-1           OK
cmake                   2.0.3-1            OK
cpio                    2.5-3              OK
crypt                   1.1-1              OK
ctags                   5.5-4              OK
cvs                     1.11.6-3           OK
cygipc                  2.03-2             OK
cygutils                1.2.5-1            OK
cygwin                  1.5.10-3           OK
dejagnu                 20021217-2         OK
diffutils               2.8.7-1            OK
editrights              1.01-1             OK
ELFIO                   1.0.0-1            OK
emacs                   21.2-13            OK
emacs-X11               21.2-13            OK
expat                   1.95.7-1           OK
expect                  20030128-1         OK
file                    4.09-1             OK
fileutils               4.1-2              OK
findutils               4.1.7-4            OK
flex                    2.5.4a-3           OK
fontconfig              2.2.2-1            OK
fortune                 1.8-2              OK
freetype2               2.1.5-1            OK
gawk                    3.1.4-3            OK
gcc                     3.3.3-3            OK
gcc-core                3.3.3-3            OK
gcc-g++                 3.3.3-3            OK
gcc-mingw               20040810-1         OK
gcc-mingw-core          20040810-1         OK
gcc-mingw-g++           20040810-1         OK
gdb                     20030919-1         OK
gdbm                    1.8.3-7            OK
gettext                 0.14.1-1           OK
gmp                     4.1.2-1            Incomplete
gperf                   2.7.2-1            OK
grep                    2.5-1              OK
groff                   1.18.1-2           OK
gzip                    1.3.5-1            OK
indent                  2.2.9-1            OK
ioperm                  0.4-1              OK
less                    381-1              OK
libbz2_1                1.0.2-5            OK
libdb3.1                3.1.17-2           OK
libdb4.2                4.2.52-1           OK
libfontconfig1          2.2.2-1            OK
libfreetype26           2.1.5-1            OK
libgdbm                 1.8.0-5            OK
libgdbm-devel           1.8.3-7            OK
libgdbm3                1.8.3-3            OK
libgdbm4                1.8.3-7            OK
libgettextpo0           0.14.1-1           OK
libiconv2               1.9.2-1            OK
libintl                 0.10.38-3          OK
libintl1                0.10.40-1          OK
libintl2                0.12.1-3           OK
libintl3                0.14.1-1           OK
libjpeg62               6b-11              OK
libjpeg6b               6b-8               OK
libncurses5             5.2-1              OK
libncurses6             5.2-8              OK
libncurses7             5.3-4              OK
libpcre                 4.1-1              OK
libpcre0                4.5-1              OK
libpng12                1.2.5-4            OK
libpopt0                1.6.4-4            OK
libreadline4            4.1-2              OK
libreadline5            4.3-5              OK
libtiff3                3.6.0-2            OK
libtiff4                3.6.0-5            OK
libungif                4.1.0-3            OK
libXft                  2.1.6-1            OK
libXft1                 1.0.0-1            OK
libXft2                 2.1.6-1            OK
login                   1.9-7              OK
lynx                    2.8.4-8            OK
m4                      1.4-1              OK
make                    3.80-1             OK
man                     1.5k-3             OK
mingw-runtime           3.3-1              OK
minires                 0.97-1             OK
mktemp                  1.5-3              OK
more                    2.11o-1            OK
nano                    1.2.2-1            OK
ncurses                 5.3-4              OK
openssh                 3.9p1-1            OK
openssl                 0.9.7d-1           OK
openssl096              0.9.6j-1           OK
patch                   2.5.8-8            OK
patchutils              0.2.30pre1-1       OK
pcre                    4.5-1              OK
pcre-doc                4.5-1              OK
perl                    5.8.5-3            OK
pilrc                   3.1                OK
prc-tools               2.3                OK
prc-tools-htmldocs      2.3                OK
python                  2.3.4-2            OK
readline                4.3-5              OK
rsync                   2.6.2-2            OK
ruby                    1.8.1-1            OK
rxvt                    2.7.10-4           OK
sed                     4.1.2-1            OK
sh-utils                2.0.15-4           OK
sharutils               4.2.1-3            OK
splint                  3.1.1-1            OK
tar                     1.13.25-5          OK
tcltk                   20030901-1         OK
tcsh                    6.13.00-2          OK
termcap                 20021106-2         OK
terminfo                5.3_20030726-1     OK
texinfo                 4.2-4              OK
textutils               2.0.21-1           OK
time                    1.7-1              OK
unzip                   5.50-5             OK
w32api                  2.5-1              OK
wget                    1.9.1-1            OK
which                   1.5-2              OK
whois                   4.6.14-1           OK
X-startup-scripts       1.0.8-1            OK
Xaw3d                   1.5D-5             OK
XFree86-base            4.3.0-11           OK
XFree86-bin             4.3.0-21           OK
XFree86-etc             4.3.0-12           OK
XFree86-fenc            4.3.0-2            OK
XFree86-fnts            4.3.0-2            OK
XFree86-lib             4.3.0-3            OK
XFree86-lib-compat      4.3.0-2            OK
XFree86-startup-scripts 4.3.0-1            OK
XFree86-xserv           4.3.0-68           OK
xorg-x11-base           6.7.0.0-8          OK
xorg-x11-bin            6.7.0.0-4          OK
xorg-x11-bin-dlls       6.7.0.0-5          OK
xorg-x11-bin-lndir      6.7.0.0-2          OK
xorg-x11-etc            6.7.0.0-3          OK
xorg-x11-fenc           6.7.0.0-2          OK
xorg-x11-fnts           6.7.0.0-1          OK
xorg-x11-libs-data      6.7.0.0-3          OK
xorg-x11-xwin           6.7.0.0-12         OK
zip                     2.3-6              OK
zlib                    1.2.1-1            OK
Path?
PATH=/opt/rtems-4.6/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/cygdriv
e/g/WIN2K/system32:/cygdrive/g/WIN2K:/cygdrive/g/WIN2K/System32/Wbem:/cygdri
ve/d/apps/cvs:/usr/bin:/cygdrive/d/apps/diab/4.3g/win32/bin:/cygdrive/d/apps
/tex/miktex/bin:/cygdrive/c/util:/cygdrive/d/apps/bc5/BIN:/cygdrive/c/DOS:/c
ygdrive/c/DOS
I'm now rerunning the configure and make all with a simple path
(/opt/rtems-4.6/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin) to see if
it makes any difference.  If not, I'll attempt to unset a bunch of the
win32 environment crud and test again.
newell
