Memory alignment on i386
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Aug 27 18:18:42 UTC 2004
CamiloAlejo at netscape.net wrote:
> Hello,
> I'm using rtems 4.6 with pc486 BSP. As far as I can see, the memory is byte-aligned, but I would like to change it to dword-aligned.
> Is there any way to set it?
What memory do you think is memory-aligned?  Heap? Stack? something
setup in the linker script?  Different ways to do the different
memory areas.
--joel
> Thanks,
> Camilo Alejandro Arboleda
> __________________________________________________________________
> Switch to Netscape Internet Service.
> As low as $9.95 a month -- Sign up today at http://isp.netscape.com/register
> Netscape. Just the Net You Need.
> New! Netscape Toolbar for Internet Explorer
> Search from anywhere on the Web and block those annoying pop-ups.
> Download now at http://channels.netscape.com/ns/search/install.jsp
