make problem with cygwin
Scott Newell newell at cei.net
Fri Aug 27 18:29:40 UTC 2004
At 01:17 PM 8/27/2004 , Scott Newell wrote:
>Next: set the /onecpu switch in boot.ini, reboot, and try again.
Nope, still borked:
configure: configuring in libmisc
configure: running /bin/bash
'../../../../../../rtems-4.6.1/c/src/../../cpukit/libmisc/configure'
--prefix=/opt/rtems-4.6  '--prefix=/opt/rtems-4.6' '--host=m68k-rtems'
'--build=i686-pc-cygwin' '--target=m68k-rtems' '--disable-posix'
'--disable-networking' '--disable-cxx' '--with-target-subdir=m68k-rtems'
'--exec-prefix=/opt/rtems-4.6/m68k-rtems' 'build_alias=i686-pc-cygwin'
'host_alias=m68k-rtems' 'target_alias=m68k-rtems' 'RTEMS_BSP=dmv152'
'RTEMS_CPU_MODEL=m68020' 'RTEMS_BSP_FAMILY=dmv152' 'CFLAGS_OPTIMIZE_V=-O4
-fomit-frame-pointer' '--with-project-root=../../'
'--enable-rtemsbsp=dmv152' '--cache-file=/dev/null'
'--srcdir=../../../../../rtems-4.6.1/c/src/../../cpukit'
--srcdir=../../../../../../rtems-4.6.1/c/src/../../cpukit/libmisc
configure: error: invalid variable name: build_alias
configure: error: /bin/bash
'../../../../../../rtems-4.6.1/c/src/../../cpukit/libmisc/configure' failed
for libmisc
'../../../../../rtems-4.6.1/c/src/../../cpukit/configure' failed for
../../cpukit
gmake[2]: *** [dmv152] Error 1
gmake[2]: Leaving directory `/build-rtems/m68k-rtems/c'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/build-rtems/m68k-rtems/c'
gmake: *** [all-recursive] Error 1
newell
