4.6.1 build problems
rtwas rtwas at comcast.net
Tue Aug 31 00:48:52 UTC 2004
Hello,
I'm running rh9
I've installed:
rtems-4.6.1.tar
rtems-4.6-rtems-base-binutils-2.13.2.1-2.i686.rpm
rtems-4.6-i386-rtems-binutils-2.13.2.1-2.i686.rpm
rtems-4.6-rtems-base-gcc-gcc3.2.3newlib1.11.0-3.i686.rpm
rtems-4.6-i386-rtems-gcc-gcc3.2.3newlib1.11.0-3.i686.rpm
rtems-4.6-rtems-base-gdb-5.2-1.i686.rpm
rtems-4.6-i386-rtems-gdb-5.2-1.i686.rpm
Based on my understanding of the instructions I created a seperate
directory ./i386 and
using the pc386 HOWTO insructions I cd to ./i386 and run:
 ../rtems-4.6.1/configure --target=i386-rtems  --enable-rtemsbsp=pc386
configurations seems to work ok and it says:
'gmake all' will build the following BSPs: pc386.
So I do and it at some point I get:
Making all in .
gmake[2]: Entering directory
`/usr2/packages/rtems/rtems-4.6.1/i386/i386-rtems/c'
gmake[2]: Nothing to be done for `all-am'.
gmake[2]: Leaving directory
Making all in pc386
`/usr2/packages/rtems/rtems-4.6.1/i386/i386-rtems/c/pc386'
gmake[2]: *** No rule to make target `all'.  Stop.
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory
gmake: *** [all-recursive] Error 1
Thanks for your help
Robert Wasierski
ATA
