4.6.1 build problems
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue Aug 31 13:47:46 UTC 2004
This doesn't seem to have enough information.  Did the
untar finish?  Did the configure finish successfully?
Do you have /opt/rtems-4.6/bin at the front of your
PATH?
On RH9, this should just work.
--joel
rtwas wrote:
> Hello,
> I'm running rh9
> I've installed:
> rtems-4.6.1.tar
> rtems-4.6-rtems-base-binutils-2.13.2.1-2.i686.rpm
> rtems-4.6-i386-rtems-binutils-2.13.2.1-2.i686.rpm
> rtems-4.6-rtems-base-gcc-gcc3.2.3newlib1.11.0-3.i686.rpm
> rtems-4.6-i386-rtems-gcc-gcc3.2.3newlib1.11.0-3.i686.rpm
> rtems-4.6-rtems-base-gdb-5.2-1.i686.rpm
> rtems-4.6-i386-rtems-gdb-5.2-1.i686.rpm
> Based on my understanding of the instructions I created a seperate
> directory ./i386 and
> using the pc386 HOWTO insructions I cd to ./i386 and run:
> ../rtems-4.6.1/configure --target=i386-rtems  --enable-rtemsbsp=pc386
> configurations seems to work ok and it says:
> 'gmake all' will build the following BSPs: pc386.
> So I do and it at some point I get:
> Making all in .
> gmake[2]: Entering directory
> `/usr2/packages/rtems/rtems-4.6.1/i386/i386-rtems/c'
> gmake[2]: Nothing to be done for `all-am'.
> gmake[2]: Leaving directory
> Making all in pc386
> `/usr2/packages/rtems/rtems-4.6.1/i386/i386-rtems/c/pc386'
> gmake[2]: *** No rule to make target `all'.  Stop.
> gmake[1]: *** [all-recursive] Error 1
> gmake[1]: Leaving directory
> gmake: *** [all-recursive] Error 1
> Thanks for your help
> Robert Wasierski
> ATA
