PPC405GPr with RTEMS + Support?
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Thu Aug 5 16:45:50 UTC 2004
Greg Broten wrote:
> Joel:
> I can understand Gene's confusion since RTEMS lists support for the
> PPC 4xx series. IBM defines about 8 processors in this series starting
> with the 403GCX, ranging to the 440GP.
> Without downloading RTEMS is there anyway of determining which specific
> chip/board combinations are supported?
The best way without a full download is probably to just browse CVS.
http://www.rtems.com/cgi-bin/cvsweb.cgi/rtems/c/src/lib/libcpu/powerpc/
is the libcpu directory where the model specific issues are addressed.
configure.ac looks at the RTEMS_CPU_MODEL and picks the subdirectories
that are needed. It looks to me that the 405 is supported as a
variant of the 403 and uses the same ppc403 subdirectory.
http://www.rtems.com/cgi-bin/cvsweb.cgi/rtems/c/src/lib/libbsp/powerpc/
is where all the full PowerPC BSPs are found. Sometimes a support
for a CPU model is submitted without an accompanying BSP. This is
common when a board is proprietary.
Thomas Doerfler provides BSP development and wrote the helas403
BSP originally. He would be a good resource also. Wow! Thomas
submitted that in Sept 98. Time flies.
--joel
> Greg B.
> And the major difference between the 405GP and 405GPr seems to be speed
> (up to 400MHz from 266MHz)
> On Thu, 2004-08-05 at 10:13, Joel Sherrill wrote:
>>I must have missed the initial post. :(
>>There is a 405GP BSP in the tree now. How is this part different?
>>And yes. Joel/OAR still offers support and development.
>>At this point, there are also others who offer BSP
>>development.
>>--joel
>>Greg Broten wrote:
>>>Gene:
>>> David Querbach, at Real Time Systems, did the port of RTEMS to the
>>>MPC555. He certainly could help you with the 405Gpr.
>>> See this website: http://www.realtime.bc.ca/
>>>Greg B.
>>>PS
>>>Love to see RTEMS for the PPC405Gpr. And by the way if you are looking
>>>at a board such at the 405Gpr from Embedded Planet, you can download
>>>TimeSys Linux for free for that board.
>>>On Wed, 2004-08-04 at 14:04, Smith, Gene wrote:
>>>>Does anybody on the list know if the IBM (but soon to be AMCC) PowerPC
>>>>device PPC405GPr will run RTEMS? It also has a built-in ethernet
>>>>controller. The part is described here:
>>>>http://www-3.ibm.com/chips/techlib/techlib.nsf/products/PowerPC_405GP_Embedded_Processor
>>>>There is (or was) a demo/eval board available commonly called "walnut"
>>>>but I don't see a BSP on RTEMS site for it. Seems to be mostly supported
>>>>by QNX.
>>>>Also, does OAR or Joel still provide RTEMS support?
>>>>Thanks,
>>>>-gene
joel at OARcorp.com On-Line Applications Research
