CRC
Carlos Bruno Silva
cbsilva at student.dei.uc.pt
Tue Aug 17 21:49:07 UTC 2004
My board is an Atmel TSC695. I have checked the docs I have but so far
did not find anything about a CRC routine in the debug monitor. Do you
know if it has one?
Carlos S.
Kamen Penev wrote:
> Carlos,
> Depending on the generative polynomial you can get different formulas
> for computing a CRC. I am attaching a program that generates several
> popular varieties of CRC routines. I've used a couple of them
> successfully.
> I don't know who the author is. I got this off the Net.
> But before you go any further, see if the debug monitor (if you have
> one) on your board already provides a CRC routine. Many do.
> Kamen
> /* This program will write six C routines for the calculation of
> * the following CRC's. */
> /* The CRC polynomial.
> * These 4 values define the crc-polynomial.
> * If you change them, you must change crctab[]'s initial value to what is
> * printed by initcrctab() [see 'compile with -DMAKETAB' above].
> /* This tables assumes CCITT is MSB first. Swapped means LSB first.
> In that
> * case the polynomial is also swapped
> /* 16 bit crc's */
> /* Value used by: CCITT KERMIT ARC BINHEX */
> /* the poly: 0x1021 0x8408 0xA001 0x1021 */
> /* original: 0x1021 0x1021 0x8005 0x1021 */
> /* init value: -1 0 0 0 */
> /* swapped: no yes yes no */
> /* bits in CRC: 16 16 16 16 */
> /* ARC used by LHARC, ZOO, STUFFIT */
> /* BINHEX used by XMODEM, PACKIT */
> /* 32 bit crc's */
> /* Value used by: CCITT32 ZIP */
> /* the poly: 0x04c11db7 0xedb88320 */
> /* original: 0x04c11db7 0x04c11db7 */
> /* init value: -1 -1 */
> /* swapped no yes */
> /* bits in CRC: 32 32 */
> /* ZIP used by COMPACTOR */
> #include <stdio.h>
> extern void exit();
> extern char *strcat();
> static void initcrctab();
> main()
> initcrctab("ccitt", 0x1021, 0xffff, 0, 16);
> initcrctab("kermit", 0x8408, 0, 1, 16);
> initcrctab("arc", 0xa001, 0, 1, 16);
> initcrctab("binhex", 0x1021, 0, 0, 16);
> initcrctab("ccitt32",0x04c11db7,0xffffffff,0,32);
> initcrctab("zip",0xedb88320,0xffffffff,1,32);
> exit(0);
> /*NOTREACHED*/
> static void initcrctab(name, poly, init, swapped, bits)
> char *name;
> int poly, init, swapped, bits;
> register int b, i;
> unsigned short v;
> unsigned long vv;
> FILE *fd;
> char buf[20];
> buf[0] = 0;
> (void)strcat(buf, name);
> (void)strcat(buf, ".c");
> if((fd = fopen(buf, "w")) == NULL) {
> (void)fprintf(stderr, "Cannot open %s for writing\n", buf);
> exit(1);
> (void)fprintf(fd, "unsigned long %s_crcinit = %d;\n", name, init);
> (void)fprintf(fd, "\n");
> if(bits == 16) {
> (void)fprintf(fd, "static unsigned short crctab[256] = {\n");
> } else {
> (void)fprintf(fd, "static unsigned long crctab[256] = {\n");
> (void)fprintf(fd, " ");
> if(bits == 16) {
> for(b = 0; b < 256; ++b) {
> if(swapped) {
> for(v = b, i = 8; --i >= 0;)
> v = v & 1 ? (v>>1)^poly : v>>1;
> } else {
> for(v = b<<8, i = 8; --i >= 0;)
> v = v & 0x8000 ? (v<<1)^poly : v<<1;
> (void)fprintf(fd, "0x%.4x,", v & 0xffff);
> if((b&7) == 7) {
> if(b != 255) (void)fprintf(fd, " ");
> } else {
> } else {
> if(swapped) {
> for(vv = b, i = 8; --i >= 0;)
> vv = vv & 1 ? (vv>>1)^poly : vv>>1;
> } else {
> for(vv = b<<24, i = 8; --i >= 0;)
> vv = vv & 0x80000000 ? (vv<<1)^poly : vv<<1;
> (void)fprintf(fd, "0x%.8x,", vv & 0xffffffff);
> if((b&3) == 3) {
> } else {
> (void)fprintf(fd, "};\n");
> (void)fprintf(fd, "unsigned long %s_updcrc(icrc, icp, icnt)\n", name);
> (void)fprintf(fd, " unsigned long icrc;\n");
> (void)fprintf(fd, " unsigned char *icp;\n");
> (void)fprintf(fd, " int icnt;\n");
> (void)fprintf(fd, "{\n");
> if(bits == 16) {
> (void)fprintf(fd, "#define M1 0xff\n");
> (void)fprintf(fd, "#define M2 0xff00\n");
> } else {
> (void)fprintf(fd, "#define M1 0xffffff\n");
> (void)fprintf(fd, "#define M2 0xffffff00\n");
> (void)fprintf(fd, " register unsigned long crc = icrc;\n");
> (void)fprintf(fd, " register unsigned char *cp = icp;\n");
> (void)fprintf(fd, " register int cnt = icnt;\n");
> (void)fprintf(fd, " while(cnt--) {\n");
> if(bits == 16) {
> if (swapped) {
> (void)fprintf(fd,
> "\tcrc=((crc>>8)&M1)^crctab[(crc&0xff)^*cp++];\n");
> } else {
> (void)fprintf(fd,
> "\tcrc=((crc<<8)&M2)^crctab[((crc>>8)&0xff)^*cp++];\n");
> } else {
> if(swapped) {
> (void)fprintf(fd,
> } else {
> (void)fprintf(fd,
> "\tcrc=((crc<<8)&M2)^crctab[((crc>>24)&0xff)^*cp++];\n");
> (void)fprintf(fd, " }\n");
> (void)fprintf(fd, " return(crc);\n");
> (void)fprintf(fd, "}\n");
> (void)fclose(fd);
