RPM Question (new OS :)
Ralf Corsepius
ralf_corsepius at rtems.org
Fri Aug 20 05:14:06 UTC 2004
On Fri, 2004-08-20 at 02:46, Joel Sherrill wrote:
> Hi,
> I am beginning to consider upgrading the OS on the machine
> used to build RTEMS RPMs from RedHat 7.3 to Fedora Core 1. Would
> this cause anyone issues?
It depends on what you mean ;)
If you mean to discontinue rh7.3-built binaries and replace them by FC1
compiled binaries, then this will probably render rpms and binaries
unusable for many users (RH < FC1; probably all Debian and SuSE users).
So I'd rather not discontinue supporting rh7.3.
Adding FC1 compiled binaries and making it your primary host/testing
system, however would be fine with me.
Work-around: Build rh7.3 binaries in a rh7.3 chroot on FC1.
Ralf
