make problem with cygwin
    Martin R. Calsyn
    martin at commonspace.net
    Thu Aug 26 15:13:05 UTC 2004
I ran into this same problem.  The 'multiple targets' error is a bit
misleading.  I solved the error by removing the .PRECIOUS entry/entries
on or immediately before the line indicated (567 in your example below).
I encountered this in perhaps six makefiles and each time it was solved
by removing a dotted makefile directive.
I haven't dug deeper into why this is happening - it seems to be an
incompatibility with the 'make' packaged in cygwin.  I haven't submitted
deltas because I don't have enough confidence that this is a proper fix
or just a workaround for cygwin weirdness.
FWIW, I am running WinXP SP1 on a dual-proc AMD 1900+ with 1Gb mem, CA
eTrust AV, and a heavy process mix.
--Martin
-----Original Message-----
From: Haberhausen, Dierk [mailto:Dierk.Haberhausen at wincor-nixdorf.com]
Sent: Thursday, August 26, 2004 6:52 AM
To: 'rtems-users at rtems.com'
Subject: make problem with cygwin
Hello,
I try to build rtems with cygwin on a windows XP system (No Virus
Checker, /
mounted with -b option, sh shell, path set to
C:\Cygwin\bin;C:\Cygwin\usr\bin;C:\cygwin\opt\rtems-4.6\bin).
The configuration with "../rtems-4.6.1/configure --target=i386-rtems
--enable-rtemsbsp=pc386 --prefix=/opt/rtems-4.6" is done with no error.
But the make all finished with following error:
Makefile:567: ***multiple target pattern. Stop.
make[4]: Leaving directory
'/rtems/tools/ib-rtems/i386-rtems/c/pc386/optman'
make[3]: *** [preinstall-recursive] Error 1
make[3]: Leaving directory '/rtems/tools/ib-rtems/i386-rtems/c/pc386'
make[2]: *** [pc386] Error 1
make[2]: Leaving directory '/rtems/tools/ib-rtems/i386-rtems/c'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/rtems/tools/ib-rtems/i386-rtems/c'
make: *** [all-recursive] Error 1
I have tried other targets and configuration options but it is always
the
same error.
I try the same under Linux and it works with no errors. But that's not a
solution for me because I will work on windows.
So if anyone can tell me what I do wrong it would be nice!
Best regards,
Dierk
