"build_alias" again in cygwin
Scott Newell
newell at cei.net
Thu Aug 26 18:13:39 UTC 2004
Someone pointed out that the cygwin binaries are available for download, so
I tried a couple of rtems builds. Building only the efi332 bsp took about
9 minutes on my machine and completed cleanly, with no build_alias errors.
However, building all the m68k bsps did not complete due to the dreaded
build_alias problem:
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating src/imfs/Makefile
config.status: creating src/dosfs/Makefile
config.status: creating config.h
config.status: executing depfiles commands
configure: configuring in libmisc
configure: running /bin/bash
'../../../../../../rtems-4.6.1/c/src/../../cpukit/l
ibmisc/configure' --prefix=/opt/rtems-4.6 '--prefix=/opt/rtems-4.6'
'--host=m68
k-rtems' '--build=i686-pc-cygwin' '--target=m68k-rtems' '--disable-posix'
'--dis
able-networking' '--disable-cxx' '--with-target-subdir=m68k-rtems'
'--exec-prefi
x=/opt/rtems-4.6/m68k-rtems' 'build_alias=i686-pc-cygwin'
'host_alias=m68k-rtems
' 'target_alias=m68k-rtems' 'RTEMS_BSP=dmv152' 'RTEMS_CPU_MODEL=m68020'
'RTEMS_B
SP_FAMILY=dmv152' 'CFLAGS_OPTIMIZE_V=-O4 -fomit-frame-pointer'
'--with-project-r
oot=../../' '--enable-rtemsbsp=dmv152' '--cache-file=/dev/null'
'--srcdir=../../
../../../rtems-4.6.1/c/src/../../cpukit' --cache-file=/dev/null
--srcdir=../../.
./../../../rtems-4.6.1/c/src/../../cpukit/libmisc
configure: error: invalid variable name: build_alias
configure: error: /bin/bash
'../../../../../../rtems-4.6.1/c/src/../../cpukit/li
bmisc/configure' failed for libmisc
'../../../../../rtems-4.6.1/c/src/../../cpukit/confi
gure' failed for ../../cpukit
gmake[2]: *** [dmv152] Error 1
gmake[2]: Leaving directory `/build-rtems/m68k-rtems/c'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/build-rtems/m68k-rtems/c'
gmake: *** [all-recursive] Error 1
Here's my cygwin environment:
!D:=D:\cygwin\bin
!G:=G:\Documents and Settings\Administrator\Desktop
ALLUSERSPROFILE=G:\Documents and Settings\All Users
APPDATA=G:\Documents and Settings\Administrator\Application Data
COMMONPROGRAMFILES=G:\Program Files\Common Files
COMPUTERNAME=NEWELL
COMSPEC=G:\WIN2K\system32\cmd.exe
CVSROOT=:XXX:XXX at XXX:/usr/local/cvsroot
CVS_RSH=/bin/ssh
HOME=/home/Administrator
HOMEDRIVE=G:
HOMEPATH=\
HOSTNAME=newell
INFOPATH=/usr/local/info:/usr/info:/usr/share/info:/usr/autotool/devel/info:
/usr/autotool/stable/info:
LM_LICENSE_FILE=d:\apps\flexlm\license.dat
LOGONSERVER=\\NEWELL
MAKE_MODE=unix
MANPATH=/usr/local/man:/usr/man:/usr/share/man:/usr/autotool/devel/man::/usr
/ssl/man
NUMBER_OF_PROCESSORS=2
OLDPWD=/
OS2LIBPATH=G:\WIN2K\system32\os2\dll;
OS=Windows_NT
PATH=/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/cygdrive/g/WIN2K/system32:
/cygdrive/g/WIN2K:/cygdrive/g/WIN2K/System32/Wbem:/cygdrive/d/apps/cvs:/usr/
bin:/cygdrive/d/apps/diab/4.3g/win32/bin:/cygdrive/d/apps/tex/miktex/bin:/cy
gdrive/c/util:/cygdrive/d/apps/bc5/BIN:/cygdrive/c/DOS:/cygdrive/c/DOS:/opt/
rtems-4.6/bin
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 15 Model 2 Stepping 9, GenuineIntel
PROCESSOR_LEVEL=15
PROCESSOR_REVISION=0209
PROMPT=$P$G
PS1=\[\033]0;\w\007
\033[32m\]\u@\h \[\033[33m\w\033[0m\]
PWD=/build-rtems
SHLVL=1
SYSTEMDRIVE=G:
SYSTEMROOT=G:\WIN2K
TEMP=/cygdrive/g/temp
TERM=cygwin
TMP=/cygdrive/g/temp
USER=Administrator
USERDOMAIN=NEWELL
USERNAME=Administrator
USERPROFILE=G:\Documents and Settings\Administrator
WINDIR=G:\WIN2K
_=/usr/bin/env
cygcheck -c:
Cygwin Package Information
Package Version Status
_update-info-dir 00221-1 OK
ash 20031007-1 OK
autoconf 2.57a-1 OK
autoconf-devel 2.57-2 OK
autoconf-stable 2.13-5 OK
automake 1.7.5a-1 OK
automake-devel 1.7.6-2 OK
automake-stable 1.4p5-6 OK
base-files 2.6-1 OK
base-passwd 1.1-1 OK
bash 2.05b-16 OK
bc 1.06-1 OK
binutils 20030901-1 OK
bison 20030307-1 OK
byacc 1.9-1 OK
bzip2 1.0.2-5 OK
check 0.8.4-1 OK
clear 1.0-1 OK
clisp 2.31-2 OK
cmake 1.8.1-1 OK
cpio 2.5-3 OK
crypt 1.1-1 OK
ctags 5.5-4 OK
cvs 1.11.6-3 OK
cygipc 2.02-1 OK
cygutils 1.2.2-1 OK
cygwin 1.5.5-1 OK
dejagnu 20021217-2 OK
diffutils 2.8.4-1 OK
editrights 1.01-1 OK
ELFIO 1.0.0-1 OK
emacs 21.2-12 OK
emacs-X11 21.2-12 OK
expat 1.95.6-2 OK
expect 20030128-1 OK
file 4.03-2 OK
fileutils 4.1-2 OK
findutils 4.1.7-4 OK
flex 2.5.4a-3 OK
fortune 1.8-2 OK
gawk 3.1.3-3 OK
gcc 3.3.1-2 OK
gcc-mingw 20030911-3 OK
gdb 20030919-1 OK
gdbm 1.8.3-7 OK
gettext 0.12.1-3 OK
gmp 4.1.2-1 OK
gperf 2.7.2-1 OK
grep 2.5-1 OK
groff 1.18.1-2 OK
gzip 1.3.5-1 OK
indent 2.2.8-1 OK
ioperm 0.4-1 OK
less 381-1 OK
libbz2_1 1.0.2-5 OK
libdb3.1 3.1.17-2 OK
libgdbm 1.8.0-5 OK
libgdbm-devel 1.8.3-7 OK
libgdbm3 1.8.3-3 OK
libgdbm4 1.8.3-7 OK
libgettextpo0 0.12.1-3 OK
libiconv2 1.9.1-3 OK
libintl 0.10.38-3 OK
libintl1 0.10.40-1 OK
libintl2 0.12.1-3 OK
libjpeg6b 6b-8 OK
libncurses5 5.2-1 OK
libncurses6 5.2-8 OK
libncurses7 5.3-4 OK
libpcre 4.1-1 OK
libpcre0 4.4-2 OK
libpng12 1.2.5-4 OK
libpopt0 1.6.4-4 OK
libreadline4 4.1-2 OK
libreadline5 4.3-5 OK
libtiff3 3.6.0-2 OK
login 1.9-7 OK
lynx 2.8.4-7 OK
m4 1.4-1 OK
make 3.80-1 OK
man 1.5j-2 OK
mingw-runtime 3.2-1 OK
mktemp 1.5-3 OK
more 2.11o-1 OK
nano 1.2.2-1 OK
ncurses 5.3-4 OK
openssh 3.7.1p2-1 OK
openssl 0.9.7c-1 OK
openssl096 0.9.6j-1 OK
patch 2.5.8-8 OK
patchutils 0.2.22-2 OK
pcre 4.4-2 OK
pcre-doc 4.4-2 OK
perl 5.8.0-5 OK
pilrc 3.1 OK
prc-tools 2.3 OK
prc-tools-htmldocs 2.3 OK
python 2.3.2-1 OK
readline 4.3-5 OK
rsync 2.5.6-2 OK
ruby 1.8.0-2 OK
rxvt 2.7.10-3 OK
sed 4.0.7-3 OK
sh-utils 2.0.15-4 OK
sharutils 4.2.1-3 OK
splint 3.1.1-1 OK
tar 1.13.25-3 OK
tcltk 20030901-1 OK
tcsh 6.12.00-7 OK
termcap 20021106-2 OK
terminfo 5.3_20030726-1 OK
texinfo 4.2-4 OK
textutils 2.0.21-1 OK
time 1.7-1 OK
unzip 5.50-5 OK
w32api 2.4-1 OK
wget 1.8.2-2 OK
which 1.5-2 OK
whois 4.6.7-1 OK
XFree86-base 4.3.0-1 OK
XFree86-bin 4.3.0-5 OK
XFree86-etc 4.3.0-3 OK
XFree86-fenc 4.2.0-3 OK
XFree86-fnts 4.2.0-3 OK
XFree86-lib 4.3.0-1 OK
XFree86-lib-compat 4.3.0-1 OK
XFree86-startup-scripts 4.2.0-5 OK
XFree86-xserv 4.3.0-20 OK
zip 2.3-5 OK
zlib 1.1.4-4 OK
What else can I do to narrow down the cause?
newell
