make problem with cygwin
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Aug 27 19:04:29 UTC 2004
Scott Newell wrote:
> At 11:31 AM 8/27/2004 , Ralf Corsepius wrote:
>>All I can tell is:
>>* Steve H. reports not to have problems.
>>AFAICT, his machine seems to be up to date or at least very close to
>>current Cygwin.
>>* Scott report to have problems. His installation is somewhat outdated.
> And Scott is still having problems:
I built the gen68360 BSP earlier and tried the dmv152 as you show.
It built for me as well.
Sorry to ask again but what exactly is your configure command?
> configure: creating ./config.status
> configure: configuring in ../../cpukit
> configure: running /bin/bash
> '../../../../../rtems-4.6.1/c/src/../../cpukit/configure'
> '--prefix=/opt/rtems-4.6' '--host=m68k-rtems' '--build=i686-pc-cygwin'
> '--target=m68k-rtems' '--disable-posix' '--disable-networking'
> '--disable-cxx' '--with-target-subdir=m68k-rtems'
> '--exec-prefix=/opt/rtems-4.6/m68k-rtems' 'build_alias=i686-pc-cygwin'
> 'host_alias=m68k-rtems' 'target_alias=m68k-rtems' 'RTEMS_BSP=dmv152'
> 'RTEMS_CPU_MODEL=m68020' 'RTEMS_BSP_FAMILY=dmv152' 'CFLAGS_OPTIMIZE_V=-O4
> -fomit-frame-pointer' '--with-project-root=../../' '--enable-rtemsbsp=dmv152'
>    --cache-file=/dev/null
> --srcdir=../../../../../rtems-4.6.1/c/src/../../cpukit
> configure: error: invalid variable name: build_alias
> configure: error: /bin/bash
> '../../../../../rtems-4.6.1/c/src/../../cpukit/configure' failed for
> ../../cpukit
> gmake[2]: *** [mvme147] Error 1
> gmake[2]: Leaving directory `/build-rtems/m68k-rtems/c'
> gmake[1]: *** [all-recursive] Error 1
> gmake[1]: Leaving directory `/build-rtems/m68k-rtems/c'
> gmake: *** [all-recursive] Error 1
> This error occured after I updated cygwin.
> Cygwin Package Information
> Package                 Version            Status
> _update-info-dir        00227-1            OK
> ash                     20040127-1         OK
> autoconf                2.59-1             OK
> autoconf-devel          2.59-1             OK
> autoconf-stable         2.13-5             OK
> automake                1.7.9-1            OK
> automake-devel          1.8.5-1            OK
> automake-stable         1.4p6-2            OK
> base-files              3.0-3              OK
> base-passwd             1.1-1              OK
> bash                    2.05b-16           OK
> bc                      1.06-1             OK
> binutils                20040725-2         OK
> bison                   20030307-1         OK
> byacc                   1.9-1              OK
> bzip2                   1.0.2-5            OK
> check                   0.8.4-1            OK
> clear                   1.0-1              OK
> clisp                   2.33.1-1           OK
> cmake                   2.0.3-1            OK
> cpio                    2.5-3              OK
> crypt                   1.1-1              OK
> ctags                   5.5-4              OK
> cvs                     1.11.6-3           OK
> cygipc                  2.03-2             OK
> cygutils                1.2.5-1            OK
> cygwin                  1.5.10-3           OK
> dejagnu                 20021217-2         OK
> diffutils               2.8.7-1            OK
> editrights              1.01-1             OK
> ELFIO                   1.0.0-1            OK
> emacs                   21.2-13            OK
> emacs-X11               21.2-13            OK
> expat                   1.95.7-1           OK
> expect                  20030128-1         OK
> file                    4.09-1             OK
> fileutils               4.1-2              OK
> findutils               4.1.7-4            OK
> flex                    2.5.4a-3           OK
> fontconfig              2.2.2-1            OK
> fortune                 1.8-2              OK
> freetype2               2.1.5-1            OK
> gawk                    3.1.4-3            OK
> gcc                     3.3.3-3            OK
> gcc-core                3.3.3-3            OK
> gcc-g++                 3.3.3-3            OK
> gcc-mingw               20040810-1         OK
> gcc-mingw-core          20040810-1         OK
> gcc-mingw-g++           20040810-1         OK
> gdb                     20030919-1         OK
> gdbm                    1.8.3-7            OK
> gettext                 0.14.1-1           OK
> gmp                     4.1.2-1            Incomplete
> gperf                   2.7.2-1            OK
> grep                    2.5-1              OK
> groff                   1.18.1-2           OK
> gzip                    1.3.5-1            OK
> indent                  2.2.9-1            OK
> ioperm                  0.4-1              OK
> less                    381-1              OK
> libbz2_1                1.0.2-5            OK
> libdb3.1                3.1.17-2           OK
> libdb4.2                4.2.52-1           OK
> libfontconfig1          2.2.2-1            OK
> libfreetype26           2.1.5-1            OK
> libgdbm                 1.8.0-5            OK
> libgdbm-devel           1.8.3-7            OK
> libgdbm3                1.8.3-3            OK
> libgdbm4                1.8.3-7            OK
> libgettextpo0           0.14.1-1           OK
> libiconv2               1.9.2-1            OK
> libintl                 0.10.38-3          OK
> libintl1                0.10.40-1          OK
> libintl2                0.12.1-3           OK
> libintl3                0.14.1-1           OK
> libjpeg62               6b-11              OK
> libjpeg6b               6b-8               OK
> libncurses5             5.2-1              OK
> libncurses6             5.2-8              OK
> libncurses7             5.3-4              OK
> libpcre                 4.1-1              OK
> libpcre0                4.5-1              OK
> libpng12                1.2.5-4            OK
> libpopt0                1.6.4-4            OK
> libreadline4            4.1-2              OK
> libreadline5            4.3-5              OK
> libtiff3                3.6.0-2            OK
> libtiff4                3.6.0-5            OK
> libungif                4.1.0-3            OK
> libXft                  2.1.6-1            OK
> libXft1                 1.0.0-1            OK
> libXft2                 2.1.6-1            OK
> login                   1.9-7              OK
> lynx                    2.8.4-8            OK
> m4                      1.4-1              OK
> make                    3.80-1             OK
> man                     1.5k-3             OK
> mingw-runtime           3.3-1              OK
> minires                 0.97-1             OK
> mktemp                  1.5-3              OK
> more                    2.11o-1            OK
> nano                    1.2.2-1            OK
> ncurses                 5.3-4              OK
> openssh                 3.9p1-1            OK
> openssl                 0.9.7d-1           OK
> openssl096              0.9.6j-1           OK
> patch                   2.5.8-8            OK
> patchutils              0.2.30pre1-1       OK
> pcre                    4.5-1              OK
> pcre-doc                4.5-1              OK
> perl                    5.8.5-3            OK
> pilrc                   3.1                OK
> prc-tools               2.3                OK
> prc-tools-htmldocs      2.3                OK
> python                  2.3.4-2            OK
> readline                4.3-5              OK
> rsync                   2.6.2-2            OK
> ruby                    1.8.1-1            OK
> rxvt                    2.7.10-4           OK
> sed                     4.1.2-1            OK
> sh-utils                2.0.15-4           OK
> sharutils               4.2.1-3            OK
> splint                  3.1.1-1            OK
> tar                     1.13.25-5          OK
> tcltk                   20030901-1         OK
> tcsh                    6.13.00-2          OK
> termcap                 20021106-2         OK
> terminfo                5.3_20030726-1     OK
> texinfo                 4.2-4              OK
> textutils               2.0.21-1           OK
> time                    1.7-1              OK
> unzip                   5.50-5             OK
> w32api                  2.5-1              OK
> wget                    1.9.1-1            OK
> which                   1.5-2              OK
> whois                   4.6.14-1           OK
> X-startup-scripts       1.0.8-1            OK
> Xaw3d                   1.5D-5             OK
> XFree86-base            4.3.0-11           OK
> XFree86-bin             4.3.0-21           OK
> XFree86-etc             4.3.0-12           OK
> XFree86-fenc            4.3.0-2            OK
> XFree86-fnts            4.3.0-2            OK
> XFree86-lib             4.3.0-3            OK
> XFree86-lib-compat      4.3.0-2            OK
> XFree86-startup-scripts 4.3.0-1            OK
> XFree86-xserv           4.3.0-68           OK
> xorg-x11-base           6.7.0.0-8          OK
> xorg-x11-bin            6.7.0.0-4          OK
> xorg-x11-bin-dlls       6.7.0.0-5          OK
> xorg-x11-bin-lndir      6.7.0.0-2          OK
> xorg-x11-etc            6.7.0.0-3          OK
> xorg-x11-fenc           6.7.0.0-2          OK
> xorg-x11-fnts           6.7.0.0-1          OK
> xorg-x11-libs-data      6.7.0.0-3          OK
> xorg-x11-xwin           6.7.0.0-12         OK
> zip                     2.3-6              OK
> zlib                    1.2.1-1            OK
> Path?
> PATH=/opt/rtems-4.6/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/cygdriv
> e/g/WIN2K/system32:/cygdrive/g/WIN2K:/cygdrive/g/WIN2K/System32/Wbem:/cygdri
> ve/d/apps/cvs:/usr/bin:/cygdrive/d/apps/diab/4.3g/win32/bin:/cygdrive/d/apps
> /tex/miktex/bin:/cygdrive/c/util:/cygdrive/d/apps/bc5/BIN:/cygdrive/c/DOS:/c
> ygdrive/c/DOS
> I'm now rerunning the configure and make all with a simple path
> (/opt/rtems-4.6/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin) to see if
> it makes any difference.  If not, I'll attempt to unset a bunch of the
> win32 environment crud and test again.
> newell
