Memory alignment on i386
CamiloAlejo at netscape.net
Fri Aug 27 19:26:11 UTC 2004
"Joel Sherrill <joel at OARcorp.com>" <joel.sherrill at OARcorp.com> wrote:
I think my question was wrong, I want every single varible defined in my app to be 32-bit aligned, but more important is having structure members 32-bit aligned by default. I want my application optimized for speed, and having non 32-bit aligned memory access can be processor consuming.
I tried to find out if '--pack-struct' was enabled, but I found nothing.
>CamiloAlejo at netscape.net wrote:
>> Hello,
>> I'm using rtems 4.6 with pc486 BSP. As far as I can see, the memory is byte-aligned, but I would like to change it to dword-aligned.
>> Is there any way to set it?
>What memory do you think is memory-aligned? Heap? Stack? something
>setup in the linker script? Different ways to do the different
>memory areas.
>--joel
>> Thanks,
>> Camilo Alejandro Arboleda
>> __________________________________________________________________
>> Switch to Netscape Internet Service.
>> As low as $9.95 a month -- Sign up today at http://isp.netscape.com/register
>> Netscape. Just the Net You Need.
>> New! Netscape Toolbar for Internet Explorer
>> Search from anywhere on the Web and block those annoying pop-ups.
>> Download now at http://channels.netscape.com/ns/search/install.jsp
>Joel Sherrill, Ph.D. Director of Research & Development
>joel at OARcorp.com On-Line Applications Research
>Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
