rtems gdb/insight to jtag
Jay Monkman
jtm-list-rtems at smoothsmoothie.com
Tue Aug 31 17:38:28 UTC 2004
On Tue, Aug 31, 2004 at 01:01:17PM -0400, Smith, Gene wrote:
> Does anyone have experience in loading and debugging rtems in a target
> having a jtag port (a.k.a. BDB, OCD)? Can it do the same things in
> debugging rtems as a rom monitor?
I use a debugger for almost all of my RTEMS work. It makes things a
lot easier. I can't think of anything a ROM monitor can do that you
can't do with a debugger. There are lots of things a monitor can't do,
or can't do well, that you can do with a debugger - debugging
interrupts, single instruction stepping, completely halting the CPU
are some.
Plug: The Abatron BDI-2000 appears to be the best debugger on the
market. It supports most 32 bit CPUs and works with GDB. It is
somewhat expensive (about $2500-$3000 plus $1000 for each additional
CPU architecture). Periodically, I look at all the other debuggers I
can find, but none match the Abatron.
Type: application/pgp-signature
Desc: Digital signature
URL: <http://lists.rtems.org/pipermail/users/attachments/20040831/3c51e56f/attachment-0001.bin>
