About AT91RM9200's EMAC driver
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Thu Dec 2 07:00:59 UTC 2004
Hi,
just a basic question: how is your sniffer attached to the
network?
If you are running the sniffer on your "host", which is directly
involved in the real ethernet communication with your target,
everything should work.
If your "sniffer" is a third machine (not the RTEMS system and
not the host), usually the network switches will ensure that any
communication between your RTEMS target and your host will be
invisible to the sniffer. Switches will send ethernet packets
only to the network trunks which lead to the system specified in
the ethernet MAC address. The only exception to this rule are
broadcast frames.
wkr,
Thomas.
> Hi, Lars
> > The network driver in csb337 bsp assumes that you have a MAC address
> > in the EMAC. Have you verified that U-BOOT puts a MAC address in the
> > EMAC before loading rtems?
> Yes, I set MAC address at the init.c before initialize the network.
> and from running network-demos-4.6.2, I can see status like below,
> and I think the config is ok.
> I'm wonder why the interrupt is always zero, like my board never
> receive a packet at all.
> Destination Gateway/Mask/Hw Flags Refs Use Expire Interface
> default 192.168.0.1 UGS 0 0 0 eth0
> 192.168.0.0 255.255.255.0 U 0 0 1 eth0
> 192.168.0.1 UHL 1 0 1 eth0
> 192.168.0.255 FF:FF:FF:FF:FF:FF UHL 0 18 0 eth0
> ************ MBUF STATISTICS ************
> mbufs:2048 clusters: 256 free: 256
> drops: 0 waits: 0 drains: 0
> free:2047 data:1 header:0 socket:0
> pcb:0 rtable:0 htable:0 atable:0
> soname:0 soopts:0 ftable:0 rights:0
> ifaddr:0 control:0 oobdata:0
> ************ INTERFACE STATISTICS ************
> ***** eth0 *****
> Ethernet Address: 00:01:02:03:04:08
> Address:192.168.0.144 Broadcast Address:192.168.0.255 Net
> mask:255.255.255.0
> Flags: Up Broadcast Running
> Send queue limit:50 length:0 Dropped:0
> Total Interrupts:0 Rx Interrupts:0
> Giant:0 Non-octet:0
> Bad CRC:0 Collision:0 Missed:0
> Tx Interrupts:0 Deferred:0 Lost
> Carrier:0
> Single Collisions:0 Multiple Collisions:0 Excessive
> Collisions:0
> Total Collisions:0 Late Collision:0
> Underrun:0
> Raw output wait:0
> ************ IP Statistics ************
> total ip packets generated here 3030
> datagrams successfully fragmented 12
> output fragments created 72
> ************ ICMP Statistics ************
> ************ UDP Statistics ************
> total output packets 3030
> ************ TCP Statistics ************
> > Btw, which version of u-boot are you using?
> > http://mmd.ath.cx/csb337-boot/ ?
> I'm using U-BOOT 1.1.1 (at91rm9200dk_config) ported by myself,
> running from ATMEL's boot. and actually I just changed the code
> about flash chip.
> Regards,
> Yanjun Luo.
> On Tue, 30 Nov 2004 10:14:22 +0100, Lars Munch wrote
> > On Tue, Nov 30, 2004 at 04:01:57PM +0800, Yanjun Luo wrote:
> > > Hi Jay,
> > > I just test AT91RM9200's EMAC driver from your CSB337 BSP.
> > > I use network-demos to test it. Whatever TCP or UDP packet
> > > I send, I can't catch it with sniffer. It seems that my board
> > > have not send anything out.
> > > My hardware is working because I use U-BOOT with TFTP to download
> > > my RTEMS image, and it works smoothly.
> > > Do you have any suggestions to test/verify it?
> > > Anyone's any hints are welcome.
> > > BTW, where can I find a ping(client) to test my system?
> > > Regards,
> > > Yanjun Luo.
> > Hello Yanjun
> > Regards
> > Lars Munch
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at: http://www.imd-
systems.de/pgp_keys.htm
