ICMP in RTEMS(fixed!)
Thu Dec 2 10:03:06 UTC 2004
Yanjun Luo wrote:
> You are right, it's a very simple problem, the initial
> driver has not set the bit EMAC_CFG_UNI, which means
> the EMAC doesn't receive unicast packet!
> My code are mess now, and it's too simple to send a
> patch I think. Also I changed the code to support
> another PHY - DM9161. If anybody think the patch is
> necessary, I'll send one.
I suggest you raise a PR on the driver and attach just the patch to fix
the unicast bit.
 Chris Johns
